Help with scrolling text code
#define CLR_WHITE 8
#define CLR_RED 2
const int led_row =5;
const int led_col=24;
int led_count= led_row *led_col;
Adafruit_NeoPixel strip = Adafruit_NeoPixel (led_count,2,NEO_GRB + NEO_KHZ800);
byte value_r=255;
byte value_g=0;
byte value_b=0;
byte color_in_row[12];
int index_animasi=0;
byte color_data[9][3]{
  {0,255,255},
  {255,255,0},
  {255,0,0},
  {0,255,0},
  {0,0,255},
  {0,255,255},
  {255,0,0},
  {0,0,255},
  {255,255,255}
const byte font_wave[] PROGMEM ={
        0x1C, 0x0A, 0x09, 0x0A, 0x1C,      // Code for char A
        0x1F, 0x15, 0x15, 0x15, 0x0A,      // Code for char B
        0x1F, 0x11, 0x11, 0x11, 0x11,      // Code for char C
        0x1F, 0x11, 0x11, 0x11, 0x0E,      // Code for char D
        0x1F, 0x15, 0x15, 0x15, 0x15,      // Code for char E
        0x1F, 0x05, 0x05, 0x05, 0x05,      // Code for char F
        0x1F, 0x11, 0x15, 0x15, 0x1D,      // Code for char G
        0x1F, 0x04, 0x04, 0x04, 0x1F,      // Code for char H
        0x11, 0x11, 0x1F, 0x11, 0x11,      // Code for char I
        0x08, 0x10, 0x10, 0x10, 0x0F,      // Code for char J
        0x1F, 0x04, 0x0E, 0x1B, 0x11,      // Code for char K
        0x1F, 0x10, 0x10, 0x10, 0x10,      // Code for char L
        0x1F, 0x02, 0x04, 0x02, 0x1F,      // Code for char M
        0x1F, 0x02, 0x04, 0x08, 0x1F,      // Code for char N
        0x0E, 0x11, 0x11, 0x11, 0x0E,      // Code for char O
        0x1F, 0x05, 0x05, 0x05, 0x07,      // Code for char P
        0x0E, 0x11, 0x15, 0x09, 0x16,      // Code for char Q
        0x1F, 0x05, 0x0D, 0x15, 0x02,      // Code for char R
        0x12, 0x15, 0x15, 0x15, 0x09,      // Code for char S
        0x01, 0x01, 0x1F, 0x01, 0x01,      // Code for char T
        0x0F, 0x10, 0x10, 0x10, 0x0F,      // Code for char U
        0x07, 0x08, 0x10, 0x08, 0x07,      // Code for char V
        0x1F, 0x08, 0x04, 0x08, 0x1F,      // Code for char W
        0x11, 0x0A, 0x04, 0x0A, 0x11,      // Code for char X
        0x01, 0x02, 0x1C, 0x02, 0x01,      // Code for char Y
        0x11, 0x19, 0x15, 0x13, 0x11       // Code for char Z
  Serial.println("Belajar Strobo #Eps.02 ShareAnimasi 001");
  strip.begin();
  strip.show();
  animation_text();
void animation_text(){
  int c=0; //kolom led
  int j=4; //jumlah huruf
  int k=5; //jumlah kolom
  char chr[4]={'H','I','N','O'};
  for (int c=0;c<led_col;c++){
  for(int h=0;h<j;h++){
    byte index_char = chr[h]-65;
    for (int a=0;a<k;a++){
      int index_char_col = index_char *k;
      byte b= pgm_read_byte(&font_wave[index_char_col+a]);
      if (b==0){
      for (int r=0;r<5;r++){
        byte b2=bitRead(b,r);
        int i = led_from_pixel(4-r,c);
        if (c>=led_col){
      else{
        int i=led_from_pixel(4-r,c);
        if (b2==1){
          strip.setPixelColor(i,strip.Color(value_r,value_g,value_b));
        else{
          strip.setPixelColor(i,strip.Color(0,0,0));
    c++;
  if (c>led_col){
      int i=led_from_pixel (r,c);
      strip.setPixelColor(i, strip.Color(0,0,0));
  c++;
  strip.show();
void color_select(int index_color){
  value_r = color_data[index_color][0];
  value_g = color_data[index_color][1];
  value_b = color_data[index_color][2];
void led_off(){
  for (int i=0;i<led_count;i++){
int led_from_pixel(byte row, byte col){
  int a=0;
  if (row%2==0){
    a = (row*led_col)+col;
    a = ((row+1)*led_col)-1-col;
  return a;
byte led_set_brightness(byte v, byte br){
  return  map(v,0,255,0,br);
Hi guys i try to make my text scrolling but, can somebod help right now it just pop the text one by one.
