Help with SDCard CSV read to Variables
Hi Everyone. I hope someone could help me with reading a csv line into some variables. This has been driving me mad for about 2 weeks with no joy, so I thought i would seeks some help from the forum.
The below code is working on a Arduino Mega. Using Pin 10 for Chipselect with SPI SDCARD. All working great. What i am trying to achieve is plain and simple im sure for most coders. Im not a great coder at all and why im stuck.
  1. All i need to do is if int weekSchedule = eg. 7, then i need to load the SCHEDULE.csv file and read line 7 data into the array and then add the data to variables. currently the code is not working this way and is instead given a number eg. 23 in the csv file so it knows to read in 23 values which currently is only loading line 1. I would rather this read in the whole line and not have to declare the 23 in the csv file at all.
  2. Now at the moment i have 2 strings
    String desiredECTotal and String desiredPHTotal and i would like these to be floats 1.8 and 5.7. not sure how to code this.
currently im updating the data from the array values to strings:
desiredECTotal = String(values[8]) + "." + String(values[9]);
desiredPHTotal = String(values[10]) + "." + String(values[11]);
This requires 4 values 8,9,10,11 as the DOT in the csv eg. 1.8,5.7 is thinking the DOT is a delimiter and causing it to be 2 values!
Now i see a new problem going to happen. if we read in a full line eg 23,1,18,27,0,60,0,0,0,1.8,5.7,27,100,7,24,20,11,13,1000,250,1,24 // < problem here in that the csv has two float values 1.8,5.7, and i dont want these as strings i need these as floats. also what happens if instead of 1.8, 5.7, some one entered 2, 5.7, my string array values would then be 3 and not 4! help!
CODE:
#include "SD.h"
#include"SPI.h"
const int SDCARD_CSpin = 10; // the CS pin for the SDCARD set to 53 on mega
// VARIABLES FOR THE SCHEDULE.CSV FILE TO LOAD TO
int weekSchedule = 7; // if this is 7 then i need to only read and load in line 7 of the schedule.csv
int week;             // if weekSchedule = 7 for eg. i need to load week 7 which is line 7 in the csv
int lightingCycle;
int nutrientAquaVegaAB;
int nutrientAquaFloresAB;
int nutrientRhizotonic;
int nutrientCanazym;
int nutrientPK1314;
int nutrientBoost;
String desiredECTotal;                      // < need these to be floats not strings!
String desiredPHTotal;                      // < need these to be floats not strings!
int desiredroomTemperature;
int desiredroomHumidity;
int lightingONTime;
int lightingOFFTime;
int desiredwaterTemp;
int wateringONTime;
int wateringOFFTime;
int defaultNutrientLevel;
int defaultPHLevel;
int ventilationONTime;
int ventilationOFFTime;
// VARIABLES FOR THE SDCARD READER
File file;        // the file name variable
String dataString;        // holds the data for the csv to be written to the SD card
int fieldIndex = 0;
    Serial.begin (9600);        // Initialize the serial port for debugging via the console
    pinMode(SDCARD_CSpin, OUTPUT);        // initialize the SDCARD CS pin
    if (SD.begin(SDCARD_CSpin)) {
    Serial.println("SD CARD IS READY!");
    Serial.println("NO SDCARD FOUND! - PLEASE INSERT SDCARD AND REBOOT THE SYSTEM");
    return;
  file = SD.open("SCHEDULE.csv");
  if (file) {        // i have a number 23 in the csv that this below code looks for to know the length of the array. i would rather this just read in the line eg line 7 if weekSchedule = 7
    char ch = file.read();        // Read the first entry - tens
    int NoF = 10 * (ch-'0');        // Change ASCII digit to a tens digit
    ch = file.read();        // Read the second entry
    NoF = NoF + ch-'0';        // Add the ones digit to the tens digit
    ch = file.read();        // read the next figure which will be a comma, but ignore it.
    unsigned long values[NoF];        // This is the array to hold the values.
    if (file.available()) {
      for (fieldIndex = 0; fieldIndex < NoF; fieldIndex ++) {
        values[fieldIndex]=file.parseInt(); //get a numerical value
      Serial.println("");
      Serial.print(fieldIndex);
      Serial.print(" FIELDS RECEIVED FROM SCHEDULE.CSV FILE: ");
      for(int i = 0; i < fieldIndex; i++) {
        Serial.print(values[i]);
      fieldIndex = 0; //reset the indexer
    file.close();
    Serial.println("");
    Serial.println("LOAD RECEIVED ARRAY DATA INTO THE VARIABLES");
    week = values[0];
    lightingCycle = values[1];
    nutrientAquaVegaAB = values[2];
    nutrientAquaFloresAB = values[3];
    nutrientRhizotonic = values[4];
    nutrientCanazym = values[5];
    nutrientPK1314 = values[6];
    nutrientBoost = values[7];
    desiredECTotal = String(values[8]) + "." + String(values[9]);         // < problem here in that the csv has two flaots 1.8,5.7, and i dont want these as strings i need these as floats. also what happens if instead of 1.8, 5.7, some one entered 2, 5.7, my string array values would then be 3 and not 4! help!
    desiredroomTemperature = values[12];
    desiredroomHumidity = values[13];
    lightingONTime = values[14];
    lightingOFFTime = values[15];
    desiredwaterTemp = values[16];
    wateringONTime = values[17];
    wateringOFFTime = values[18];
    defaultNutrientLevel = values[19];
    defaultPHLevel = values[20];
    ventilationONTime = values[21];
    ventilationOFFTime = values[22];
  Serial.println("");
  Serial.print("LOADED SETTINGS FOR WEEK: = ");
  Serial.println(week);
  Serial.print("Lighting Cycle (Hours): = ");
  Serial.println(lightingCycle);
  Serial.print("Nutrient Aqua Vega Dosage (ml): = ");
  Serial.println(nutrientAquaVegaAB);
  Serial.print("Nutrient Aqua Flores Dosage (ml): = ");
  Serial.println(nutrientAquaFloresAB);
  Serial.print("Nutrient Rhizotonic Dosage (ml): = ");
  Serial.println(nutrientRhizotonic);
  Serial.print("Nutrient Canazym Dosage (ml): = ");
  Serial.println(nutrientCanazym);
  Serial.print("Nutrient PK 13/14 Dosage (ml): = ");
  Serial.println(nutrientPK1314);
  Serial.print("Nutrient Boost Dosage (ml): = ");
  Serial.println(nutrientBoost);
  Serial.print("Desired EC Total: = ");
  Serial.println(desiredECTotal);
  Serial.print("Desired PH Total: = ");
  Serial.println(desiredPHTotal);
  Serial.print("Desired Room Temperature: = ");
  Serial.println(desiredroomTemperature);
  Serial.print("Desired Room Humidity: = ");
  Serial.println(desiredroomHumidity);
  Serial.print("Lighting ON Time: = ");
  Serial.println(lightingONTime);
  Serial.print("Lighting OFF Time: = ");
  Serial.println(lightingOFFTime);
  Serial.print("Desired Water Tempurature: = ");
  Serial.println(desiredwaterTemp);
  Serial.print("Watering ON Time: = ");
  Serial.println(wateringONTime);
  Serial.print("Watering OFF Time: = ");
  Serial.println(wateringOFFTime);
  Serial.print("Default Nutrient Level: = ");
  Serial.println(defaultNutrientLevel);
  Serial.print("Default PH Level: = ");
  Serial.println(defaultPHLevel);
  Serial.print("Ventilation ON Time: = ");
  Serial.println(ventilationONTime);
  Serial.print("Ventilation OFF Time: = ");
  Serial.println(ventilationOFFTime);
  Serial.println("SCHEDULE DATA UPDATED OK");
