Hello
I find this code example in the forum and made few change to use it in my project , works great for me , it reads text file in to 2d array .
what i need to do is search for value in 2 d Array
For example search for the lowest value in the left (represent speed) i and show the value belong to him j (direction)
Find the lowest speed at what direction
Can any one help with this ?
Many appreciate & Thanks in Advance
// Example to read a two dimensional array.
#include <SPI.h>
#include <SD.h>
#define CS_PIN 10
// 5 X 4 array
#define ROW_DIM 150
#define COL_DIM 2
File file;
* Read a file one field at a time.
* file - File to read.
* str - Character array for the field.G
* size - Size of str array.
* delim - String containing field delimiters.
* return - length of field including terminating delimiter.
* Note, the last character of str will not be a delimiter if
* a read error occurs, the field is too long, or the file
* does not end with a delimiter. Consider this an error
* if not at end-of-file.
size_t readField(File* file, char* str, size_t size, char* delim) {
char ch;
size_t n = 0;
while ((n + 1) < size && file->read(&ch, 1) == 1) {
// Delete CR.
if (ch == '\r') {
continue;
str[n++] = ch;
if (strchr(delim, ch)) {
str[n] = '\0';
return n;
#define errorHalt(msg) {Serial.println(F(msg)); while(1);}
// Initialize the SD.
if (!SD.begin(CS_PIN)) {
errorHalt("begin failed");
// Create or open the file.
file = SD.open("READNUM.TXT", FILE_WRITE);
if (!file) {
errorHalt("open failed");
// Rewind file so test data is not appended.
file.seek(0);
//* Write test data.
file.print(F(
"26,259\r\n"
"21,220\r\n"
"31,320\r\n"
"41,350\r\n"
"21,220\r\n"
"31,320\r\n"
"41,360\r\n"
"21,22\r\n"
"31,32\r\n"
"41,42\r\n"
"21,22\r\n"
"31,32\r\n"
"51,52,53,54" // Allow missing endl at eof.
// Rewind the file for read.
file.seek(0);
// Array for data.
int array[ROW_DIM][COL_DIM];
int i = 0; // First array index.
int j = 0; // Second array index
size_t n; // Length of returned field with delimiter.
char str[20]; // Must hold longest field with delimiter and zero byte.
char *ptr; // Test for valid field.
// Read the file and store the data.
for (i = 0; i < ROW_DIM; i++) {
for (j = 0; j < COL_DIM; j++) {
n = readField(&file, str, sizeof(str), ",\n");
if (n == 0) {
errorHalt("Too few lines");
array[i][j] = strtol(str, &ptr, 10);
if (ptr == str) {
errorHalt("bad number");
while (*ptr == ' ') {
ptr++;
// if (*ptr != ',' && *ptr != '\n' && *ptr != '\0') {
// errorHalt("extra characters in field");
if (j < (COL_DIM-1) && str[n-1] != ',') {
errorHalt("line with too few fields");
if (str[n-1] != '\n' && file.available()) {
errorHalt("missing endl");
// Print the array.
if (j) {
Serial.print(' ');
Serial.print(array[i][j]);
Serial.println("Done");
file.close();
