Help with Sensor and Motor
Hi,I am having problem with the motor and pressure sensor
I want that when I press the sensor, according to the pressure, he turns the engine, but it only works occasionally,sometimes yes and sometimes no
I'm using this code :
int motorPin = 3;
 int Senval=0;
int Senpin=A0;
pinMode(13,OUTPUT);
pinMode(2,OUTPUT);
  pinMode(motorPin, OUTPUT);
  Senval=analogRead(Senpin);
      Serial.println(Senval);
      analogWrite(motorPin,Senval);
 //analogWrite(motorPin,500);
  delay(100);
I'm able to read the value of the applied pressure, which ranges from 0 to 500
if i put digitalWrite(motorpin,HIGH); the motor work.
why sometimes the motor work,and sometimes the motor dont work.
Sorry for my bad english.
Thanks for the attention
analogueWrite should be between 1 - 255
So try the following
int motorPin=3;
int Senval=0;
int Senpin=A0;
pinMode(13,OUTPUT);
pinMode(2,OUTPUT);
      Serial.print(Senval,DEC);
      Senval=constrain(Senval,1,500);
      Senval=map(Senval,1,500,1,255);
      Serial.print (" BUT NOW CHANGED TO ");
      Serial.println(Senval,DEC);
      delay(100);
KenF:
int motorPin=3;
int Senval=0;
int Senpin=A0;
pinMode(13,OUTPUT);
pinMode(2,OUTPUT);
      delay(100);
dont work,but if i put analogWrite(motorPin,500);.the motor turn on.
Why not just
Senval = map(Senval, 1, 1023, 1, 255);
Or, even simpler
Senval = Senval / 4; // 255 = 1023 / 4 for all practical purposes
Or
Senval = Senval >> 2; // same as / 4
...R
Robin2:
Why not just
Because he only mentioned that his values get up to 500. therefore this would only give him half speed.
Robin2:
Or, even simpler
For the same reason as just mentioned
Robin2:
Or
and again.
In fact I was assuming that his sensor values are only getting up to 500. (but wasn't quite sure I believed him so added the constraint as an after thought)
KenF:
OK, I hadn't spotted the 500 limit.
Just divide by 2 instead of 4.
...R
Robin2:
Now THIS could work :slight_smile:
Dont work =s.
1 video :
But later i made this :
int motorPin=3;
int Senval=0;
int Senpin=A0;
pinMode(13,OUTPUT);
pinMode(2,OUTPUT);
     if(Senval > 0 && Senval< 50)
      analogWrite(motorPin,3000);
     }else{
       analogWrite(motorPin,0);
     if(Senval > 50 && Senval < 100)
     analogWrite(motorPin,2000);
       if(Senval > 100 && Senval < 150)
     analogWrite(motorPin,1500);
       if(Senval > 150 && Senval < 250)
     analogWrite(motorPin,1000);
       if(Senval > 250 )
     digitalWrite(motorPin,HIGH);
      delay(100);
But the motor dont varies according to the pressure gradually
Could you post a schematic of exactly how you have the motor connected.
the circuit for the sensor :
The motor connected to pin 3 and ground
saidmrn:
Never connect a motor to one of the I/O pins - it will probably damage your Arduino by drawing far too much current. It may already have damaged it. The I/O pins can only provide a max of 40mA and I suggest 20mA would be a sensible upper limit. Even small electric motors need 10 or 20 times that amount.
At the very least you need a transistor between the Arduino and the motor. Or get a h-bridge such as an L298 f you want forward and reverse control.
...R
saidmrn:
This is what I was afraid of. Robin has said it all. Ideally you should have a separate power supply for the motor and at least a transistor to drive it. Even then you’d want a current limiting resistor to the base of the transistor, and possibly a diode to prevent back EMF causing damage as you release the power.
I have transistor,diode,resistor,Do you can send me 1 circuit to mount it?
saidmrn:
http://www.ecs.umass.edu/ece/m5/tutorials/tip122_transistor_tutorial.html
i maked this circuit
the motor get connected and the speed does not change when I put the value in serialprint
int motorPin = 3;
  while (! Serial);
  Serial.println("Speed 0 to 255");
  if (Serial.available())
    int speed = Serial.parseInt();
    if (speed >= 0 && speed <= 255)
      analogWrite(motorPin, speed);
I'm not sure whether your transistor circuit is correct - I'm not good at that stuff.
But a couple of other things....
There is a real possibility that Pin 3 on your Uno is damaged already. Try using a different pin.
You really should NOT power the motor from the 5v pin. If it draws a lot of current (which it probably will) the voltage will drop and the Arduino will reset or otherwise misbehave. Give the motor a separate power supply. Just make sure GND for the motor power supply is connected to the Arduino GND - which probably means that your transistor circuit needs to be changed so it is controlling the positive side.
...R
