Hi, I’ve recently built the serial Arduino single sided from scratch. I’ve loaded the bootloader without problems, the led blinks when reset button is pressed. The problem comes when I try to upload a program using the serial cable. I’m using pin 5 for ground and 2&3 for Tx and Rx. I’m using win xp and Arduino version 09. when I try to upload the following message appears:
Binary sketch size: 862 bytes (of a 7168 byte maximum)
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
I tried everything, lower baudrate, changed the COM number, swapped Tx with Rx, pressing reset before/after upload and nothing works, I’ve no idea what to do next. Is there anything elese I should check? Please help.
I am new to Arduino and have been researching the issue with communications between a standard serial port and the Arduino. I assumed that I could connect pins 2 and 3 to the TX and RX pins on the Arduino and upload a sketch. Apparently this doesn’t work because the computer COM ports are RS232 and the ATMEL is a TTL serial chip. I didn’t know there were different protocols but Paul Badger over at www.ModernDevice.com gave me a little explanation about it. Anyway, he directed me to http://wulfden.org/pa/index.shtml#P4A and the P4 which converts RS232 to TTL serial. I ordered a few kits. I am making an assumption that the TX and RX work the same way with Pauls BBB"Arduino" and the Diecimila RX/TX being that they have the same chip. I do not know why I have not read about this on this site. Of course the confirmation of this solution will occur after the receipt, assembly and test of the P4. I will test with both BBB and Arduino.
I am amazed that this is not something addressed outside the forums. I have seen a number of forum posts about this subject with little to no resolve.
David, thanks for the information. It’ll help me to better understand how the arduino works.
nkcelectronics: I don’t know what bootloader is in my arduino, I’m using an atmega8, the serial single sided version. I just uploaded the bootloader that came with the arduino 0009.
Luckily I solved the communication problem with the board. It seems that in my current computer, although I disable the antivirus and firewall there is still a hidden, invisible program preventing me to access the serial port. I created a new user, without deleting the old of course. This new user is “cleaner”: it doesn’t has all the programs and modifications my older user has. There, I only had to disable ZoneAlarm and my little Arduino finally worked
