Help with Serial Behaviour
Hello,
I am having trouble with reading strings from a serial port using my Arduino. I send one string, it is translated correctly, and the response is perfect. However, when I send a second string, it is not translate/evaluated perfectly well and I cannot get strings sent as commands (after the first command) to be executed. Can someone help to point out where I have gone wrong in my code?
Here is the code I have been using:
char incomingChar; // for incoming serial data
char serialMessage[75];
int i = 0;
   Serial.begin(9600); // opens serial port, sets data rate to 9600 bps
  while (Serial.available() > 0) {
    // read the incoming byte:
    incomingChar = Serial.read();
    serialMessage[i] = incomingChar;
    //Serial.print(serialMessage[i]);
    i++;
    String incomingString(serialMessage);
    if(incomingString == "Stand") {
      Stand();
      Serial.print("I received: ");
      Serial.println(incomingString);
      i = 0;
    if(incomingString == "Step") {
      Step();
      i = 0;
There are some more methods within my code underneath, such as 'Stand' and 'Step', but I left those out for brevity.
Thank you
Hi @sp220
How your serial monitor is configured?
Below are 4 options.
NO LINE ENDING
NEWLINE
CARRIAGE RETURN
BOTH NL & CR
Select NO LINE ENDING and test your sketch again
RV mineirin
Serial monitor
Thank you for that! This helped a little. I made some incremental progress. I can now send 2 commands before it stops working just as it did before. Here is the amended code:
int i = 0;
    i++;
      Stand();
      i = 0;
      serialMessage[i] = 0;
      Step();
      i = 0;
I recommend the serial input basics tutorial, robust ways to read serial data.
Thank you! That took care of everything. Thanks.
Hi @sp220
Simplifying your sketch.
RV mineirin
String incomingString = "";
    incomingString = Serial.readString();
  if (incomingString == "Stand") {
    Stand();
  if (incomingString == "Step") {
    Step();
For a selection of sketches to read from Serial using Strings and SafeString see my tutorial Arduino Software Solutions
The pros and cons of each approach are listed
