Hi all, I'm working on a simple autonomous vehicle project, and I want to be able to select gps coordinates in a tkinter app I made, then send them to the arduino via Serial. I have successfully done this, but consistently I lose the first 2 coordinates I send. I cannot for the life of me figure out why I'm not getting the first 2.
Here's the arduino code that should recieve and process coords:
struct GPSCoordinate {
float latitude;
float longitude;
char inData[14];
int numCoords = 0;
GPSCoordinate coordinates[32];
while (true) {
int index = 0;
while (true) {
if (Serial.available() > 0) {
char c = Serial.read();
if (c == '\n') {
inData[index++] = '\0';
inData[index++] = c;
if (strcmp(inData, "␄") == 0) {
coordinates[numCoords] = parseCoordinateString(inData);
numCoords = numCoords+1;
Serial.print(numCoords);
Serial.println(" List of Coordinates:");
for (int i = 0; i < numCoords; i++) {
Serial.print("Latitude: ");
Serial.print(coordinates[i].latitude, 8);
Serial.print(", Longitude: ");
Serial.println(coordinates[i].longitude, 8);
GPSCoordinate parseCoordinateString(char* gpsString) {
GPSCoordinate coord;
char *lat_str = strtok(gpsString, ",");
char *lon_str = strtok(NULL, ",");
if (lat_str != NULL && lon_str != NULL) {
float lat = atof(lat_str);
float lon = atof(lon_str);
coord = {lat, lon};
return coord;
And here's the relevant python code:
def sendWaypoints(self):
coordList = []
for waypoint in self.waypointList:
coordList.append(list(waypoint.position))
print(coordList)
serialCon = serial.Serial(self.serial_port, 9600)
for coord in coordList:
lat = "{:.10f}".format(coord[0])
lon = "{:.10f}".format(coord[1])
lat_lon_str = lat+','+lon+'\n'
bytes = serialCon.write(lat_lon_str.encode())
time.sleep(.5)
time.sleep(1)
bytes = serialCon.write("␄\n".encode())
#This loop is here for debugging purposes while getting this to work
while True:
line = serialCon.readline().decode().strip()
print(line)
serialCon.close()
tkinter.messagebox.showinfo(title="", message="Waypoints sent!")
And finally here is a sample output to the terminal:
[[34.241481450236876, -77.95466705986328], [34.22530239557737, -77.95432373710938], [34.207416666176755, -77.95810028740235]]
1 List of Coordinates:
Latitude: 34.20741653, Longitude: -77.95809173
As you can see, the first 2 have vanished, and only the third has been stored, and numCoords has only been incremented 1 time.
I would appreciate any help. Thanks!
