I am making a basic environmental capture device and writing a basic command line interface so I can quickly get readings. However this is totally not working the way I expect. Here is my code:
int incomingByte = 0;
char buffer[100];
int pos=0;
Serial.begin(9600); // opens serial port, sets data rate to 9600 bps
// send data only when you receive data:
if (Serial.available() > 1)
// read the incoming byte:
incomingByte = Serial.read();
// say what you got:
Serial.print("\r\nI received: ");
Serial.print(incomingByte,DEC);
if(incomingByte==13) //enter pressed
pos=0;
//process command
if(buffer=="help")CMD_help();
else if(buffer=="astates")CMD_astates();
else if(buffer=="dstates")CMD_dstates();
else if(buffer=="allstates")CMD_allstates();
else if(buffer!="")
Serial.print("Unknown command: \"");
Serial.print(buffer);
Serial.print("\", type help for list of valid commands");
Serial.flush();
pos=0;
Serial.print("\r\n\r\n#");
buffer[pos]=incomingByte;
buffer[pos+1]=0;
pos++;
void CMD_help()
Serial.print("-------------------------------------------------------------------------------\r\n");
Serial.print("HAL9000 / EnviroState 1.0.0 [updated June 15 2012] - www.iceteks.com\r\n");
Serial.print("help...........................................................show this screen\r\n");
Serial.print("astates......................................................show analog states\r\n");
Serial.print("dstates.....................................................show digital states\r\n");
Serial.print("allstates..................................show both analong and digital states\r\n");
void CMD_astates()
void CMD_dstates()
void CMD_allstates()
CMD_astates();
CMD_dstates();
None of the if statements seem to be working. It always says it's an invalid command even though the text matches.
Am I missing something here? I've written serial/tcp programs before and used a similar way to capture the data into a buffer then process it, but for some reason this is not working out at all. I'm very new to this so maybe there's something I should be doing? When it's comparing is it comparing the ENTIRE array or is it smart enough to know to only compare all the way to \0 and NOT include the \0 in the compare?
Good to know, but yeah I'll stick to standard strings. So is this actually true c++ or just a syntax that is similar? Like can I actually use OOP and such? I probably would not write programs complex enough for that mind you, but always good to know it's available.
Here's my final app, think this will work out ok for my needs:
#include <EEPROM.h>
char buffer[100];
int pos=0;
int deviceid;
//want all digital pins to be digital inputs, no PWM needed for this app
pinMode(2, INPUT);
pinMode(3, INPUT);
pinMode(4, INPUT);
pinMode(5, INPUT);
pinMode(6, INPUT);
pinMode(7, INPUT);
pinMode(8, INPUT);
pinMode(9, INPUT);
pinMode(10, INPUT);
pinMode(11, INPUT);
pinMode(12, INPUT);
//notes: cannot use pins 0,1 and 13 as they are reserved.
deviceid=EEPROM.read(0);
if (Serial.available() > 0)
//filter unwanted chars:
if(incomingByte<13 || (incomingByte>14 && incomingByte<32) || incomingByte>126)return;
//echo back what we typed:
Serial.print((char)incomingByte);
//if enter pressed or reached end of buffer, process buffer
if(incomingByte==13 || pos>=99)
pos=0;
Serial.print("\r\n");
//process command
if(strcmp(buffer,"help")==0)CMD_help();
else if(strcmp(buffer,"id")==0)CMD_id();
else if(strcmp(buffer,"setid")==0)CMD_setid();
else if(strcmp(buffer,"astates")==0)CMD_astates();
else if(strcmp(buffer,"dstates")==0)CMD_dstates();
else if(strcmp(buffer,"allstates")==0)CMD_allstates();
else if(strcmp(buffer,"")!=0)
Serial.flush();
pos=0;
Serial.print("\r\n# ");
buffer[pos+1]=0;
pos++;
void CMD_help()
Serial.print("\r\n\r\n-------------------------------------------------------------------------------\r\n");
Serial.print("help Show this screen\r\n");
Serial.print("id Show device id\r\n");
Serial.print("setid Set device id\r\n");
Serial.print("astates Show analog states\r\n");
Serial.print("dstates Show digital states\r\n");
Serial.print("allstates Show both analong and digital states\r\n");
void CMD_id()
Serial.print(deviceid,DEC);
void CMD_setid()
Serial.print("Cur id:");
Serial.print("\r\nnew id:");
//wait for data to be available
while(Serial.available() == 0);
deviceid = Serial.read();
EEPROM.write(0,deviceid);
Serial.print("\r\nID changed\r\n");
void CMD_astates()
Serial.println(analogRead(A0));
Serial.println(analogRead(A1));
Serial.println(analogRead(A2));
Serial.println(analogRead(A3));
Serial.println(analogRead(A4));
Serial.println(analogRead(A5));
void CMD_dstates()
Serial.println(digitalRead(2));
Serial.println(digitalRead(3));
Serial.println(digitalRead(4));
Serial.println(digitalRead(5));
Serial.println(digitalRead(6));
Serial.println(digitalRead(7));
Serial.println(digitalRead(8));
Serial.println(digitalRead(9));
Serial.println(digitalRead(10));
Serial.println(digitalRead(11));
Serial.println(digitalRead(12));
CMD_astates();
CMD_dstates();
I'll be getting some scrap telco frame jumper cable tomorrow at work and then I can start connecting the inputs to my terminal block on the makeshift chassis that I made, and I'll have myself a nice little environmental data acquisition device. This is working out quite nicely. Glad I heard of Arduino!
