I’m trying to do some serial comms between an arduino and a liquidware touchscreen. It should be essentially the same as connecting an arduino to an arduino.
The premise of these sketches is that the arduino picks up signals from various sensors via it’s ADC and sends these readings to the other device as ints. Should be simple, but I haven’t been able to get it to work.
I have read this and it was helpful: Antipasto Hardware Blog: Passing large values between the Arduino to the TouchShield
arduino code
//code for arduino to use with touchshield and other programs
//pulls data from sensors and reports it across serial based on a handshake
#include <AFSoftSerial.h>
#define rxPin 3
#define txPin 2
AFSoftSerial vSerial = AFSoftSerial(rxPin, txPin);
int rtsPin = 4;
int ctsPin = 5;
int xval = 4;
int yval = 5;
int zerogy = 512;
int zerogx = 512;
//int sprayTriggerPin = 11;
//int piezoTriggerPin = 9;
int t1pin = 2;
int t2pin = 3;
int tempPin = 1;
int boostPin = 0;
int boost;
int oilT;
int t1;
int t2;
int x;
int y;
void setup(){
//setup connection to tsshield
vSerial.begin(9600);
zeroAccelerometer();
void zeroAccelerometer(){
//zero the accelerometer on startup
int tempreading = analogRead(yval);
if ((tempreading < 800) && (tempreading > 200)){
zerogy = tempreading;
else {
zerogy = 512;
tempreading = analogRead(xval);
if (true) {
zerogx = tempreading;
else {
zerogx = 512;
void loop (){
//handshake to say clear to send
while(vSerial.read() != 'U'){}
//Serial.print('U');
//listen for queries from tsshield
//full pull
char readS = vSerial.read();
if (readS == 'F'){
boost = lookup_boost(analogRead(boostPin));
oilT = lookup_oil_temp(analogRead(tempPin));
t1 = lookup_temp(analogRead(t1pin));
t2 = lookup_temp(t2pin);
sendFloat(boost);
sendFloat(oilT);
sendFloat(t1);
sendFloat(t2);
//xydisplay
if (readS == 'X'){
x = getAccelerometerData (xval);
//y = getAccelerometerData (yval);
sendFloat(x);
//sendFloat(y);
return;
void sendFloat(float sendVar){
sendVar = sendVar * 10;
int sendV = (int)sendVar;
//TODO: change to using ints with * 10
/*unsigned char lowByte, highByte;
unsigned int val;
//set val to something
char firstByte = (unsigned char)val;
char secondByte = (unsigned char)(val >> 8);
char thirdByte = (unsigned char)(val >> 16);
char fourthByte = (unsigned char)(val >> 24);
vSerial.print(firstByte);
delay(1);
vSerial.print(secondByte);
delay(1);
vSerial.print(thirdByte);
delay(1);
vSerial.print(fourthByte);*/
char lowByte = (unsigned char)sendV;
char highByte = (unsigned char)(sendV >> 8);
vSerial.print(highByte);
delay(1);
vSerial.print(lowByte);
delay(10);
//while(vSerial.read() != 'C'){} //check for clear signal before sending next
return;
//correctly changed for float values
float lookup_boost(int boost){
//boost = ( (boost-106000) / 259000 );
// boost = ( (( boost * 398) / 1000) + 2); //2 is the y intercept
//398 changed to 378 for slope...because slope was too steep
boost = ( (( boost * 378) / 1000) - 4)/10; //get rid of the divide by ten when adding decimals on display
return boost;
//code for defi/nippon-seiki temp sender
float lookup_oil_temp(int tval){
if (tval <= 200){
return 0.0;
if (tval > 200 && tval <= 315){
return .37 * tval + 47.74;
//return (37 * tval + 4774);
if (tval > 315 && tval <= 477){
return .28 * tval + 71.3;
//return (28 * tval + 7130);
if (tval > 477 && tval <= 790){
return .33 * tval + 35.59;
//return (33 * tval + 3559);
if (tval > 790){
return 999.9;
//correctly converted to float values
float lookup_temp(int tval){
if (tval < 89){
return (999.9);
if (tval > 960){
return (0.0);
if ((tval <= 960)&&(tval > 932)){
return (((tval-1015.77))/(-1.72));
if ((tval <= 932)&&(tval > 896)){
return (((tval-1042.01))/(-2.26));
if ((tval <= 896)&&(tval > 851)){
return (((tval-1077.38))/(-2.80));
if ((tval <= 851)&&(tval > 791)){
return (((tval-1122.64))/(-3.35));
if ((tval <= 791)&&(tval > 707)){
return (((tval-1175.88))/(-3.88));
if ((tval <= 707)&&(tval > 624)){
return (((tval-1214.41))/(-4.21));
if ((tval <= 624)&&(tval > 532)){
return (((tval-1223.67))/(-4.28));
if ((tval <= 532)&&(tval > 437)){
return (((tval-1186.51))/(-4.05));
if ((tval <= 437)&&(tval > 364)){
return (((tval-1113.49))/(-3.66));
if ((tval <= 364)&&(tval > 306)){
return (((tval-1022.32))/(-3.21));
if ((tval <= 306)&&(tval > 248)){
return (((tval-90.78))/(-2.70));
if ((tval <= 248)&&(tval > 200)){
return (((tval-785.75))/(-2.20));
if ((tval <= 200)&&(tval > 158)){
return (((tval-665.07))/(-1.75));
if ((tval <= 158)&&(tval > 123)){
return (((tval-553.00))/(-1.37));
if ((tval <= 123)&&(tval > 90)){
return (((tval-417.52))/(-.94));
//correctly converted to use float values
float getAccelerometerData (int axis){
int zerog = 512;
if (axis == 4){
zerog = zerogx;
if (axis == 5){
zerog = zerogy;
int rc = analogRead(axis);
int top =( (zerog - rc) ) ;
float frtrn = ((float)top/(float)158); //158Vint jumps are 1g for the ADXL213AE (original accel)
//154Vint jumps are 1g for the ADXL322 (updated one)
return frtrn;
