Help with Serial Communication
I have this code
int led3 = 3;
int led4 = 4;
int led5 = 5;
int led6 = 6;
int input = 0;
pinMode(led3,OUTPUT);
pinMode(led4,OUTPUT);
pinMode(led5,OUTPUT);
pinMode(led6,OUTPUT);
void loop () {
  input = Serial.read();
  if (input == 'q' ) {
    digitalWrite(led3,HIGH);
    Serial.println("1 is ON");
  if (input == 'a'){
      digitalWrite(led3, LOW);
      Serial.println("1 is OFF");
     if (input == 'w' ) {
    digitalWrite(led4,HIGH);
    Serial.println("2 is ON");
  if (input == 's'){
      digitalWrite(led4, LOW);
      Serial.println("2 is OFF");
    if (input == 'e' ) {
    digitalWrite(led5,HIGH);
    Serial.println("3 is ON");
  if (input == 'd'){
      digitalWrite(led5, LOW);
      Serial.println("3 is OFF");
    if (input == 'r' ) {
    digitalWrite(led6,HIGH);
    Serial.println("4 is ON");
  if (input == 'f'){
      digitalWrite(led6, LOW);
      Serial.println("4 is OFF");
I am using it to turn LED's in and off via serial. The only problem is that I would like to be able to use multiple characters and this code only allows for one character. For example, right now, i can only say "q" or "d" to turn LED's on and off. I would like to be able to say "red on " or "green off" o turn them on or off. Any help would be appreciated.
Test code that uses a delimiter.
//zoomkat 3-5-12 simple delimited ',' string parce
//from serial port input (via serial monitor)
//and print result out serial port
// CR/LF could also be a delimiter
int ledPin = 13;
String readString;
  pinMode(ledPin, OUTPUT);
  Serial.println("serial LED on/off test with , delimiter"); // so I can keep track
  if (Serial.available())  {
    char c = Serial.read();  //gets one byte from serial buffer
    if (c == ',') {
      //if (readString.length() >0) {
        Serial.println(readString); //prints string to serial port out
        //do stuff with the captured readString
        if(readString.indexOf("on") >=0)
          digitalWrite(ledPin, HIGH);
          Serial.println("LED ON");
        if(readString.indexOf("off") >=0)
          digitalWrite(ledPin, LOW);
          Serial.println("LED OFF");
        readString=""; //clears variable for new input
    else {
      readString += c; //makes the string readString
