I’m trying to tie a PWM output with a serial input. It’s acting really weird for me. I’ve set up some feedback to see what’s going on.
if (Serial.available()>0){
incomingByte = Serial.read();
Serial.println("incomingByte spot 1");
Serial.println(incomingByte,DEC);
Using this, and entering 50 for its Serial.read() input, it initially tells me that what I entered is 53. This is my first problem. Then the loop continues to
if (targetmmB > ((OCR3B+1)/20)){
if ((millis()-timeoldB) > 100){
if (OCR3B <= 1994)
OCR3B = OCR3B + x;
timeoldB = millis();
Serial.println("targetmmB spot 2");
Serial.println(targetmmB,DEC);
This time, the targetmmB value returned to me is 53, matching incomingByte.
Then the loop executes again and without entering any serial input, the serial.available() > 0 statement is true again and I’m told that the incomingByte is 48. The loop executes again and the same thing happens, but incomingByte is 10. Then the targetmmB comes to 10 and the loop then Serial.available > 0 becomes false and targetmmB stays at 10. Can anyone help me figure out what’s going on?
My complete code:
volatile byte spincount;
unsigned int spintime = 0;
unsigned long timeold = 0;
unsigned long timeoldB = 0;
unsigned long timeoldC = 0;
unsigned int x = 5; //this determines the actuator step
int feedPinB = 2;
int feedPinC = 3;
//set PWM pins for timer 4
int incomingByte = 0;
int targetmmB = 0;
int targetmmC = 0;
//attachInterrupt(2,spinfun,RISING); //pin 21
pinMode(feedPinB, OUTPUT);
pinMode(feedPinC, OUTPUT);
TCCR3A = _BV(COM3A1) | _BV(COM3B1) | _BV(COM3C1) | _BV(WGM31) | _BV(WGM30);
TCCR3B = _BV(WGM33) | _BV(WGM32)| _BV(CS30);
//set PWM setting bits, see datasheet
OCR3A = 2000; //upper count limit
OCR3B = 0; //count limit for timer B
OCR3C = 0; //count limit for timer C
/*COM3A1 - 1 COM3A0 - 0 COM3B1 - 1 COM3B0 - 0 COM3C1 - 1 COM3C0 - 0 WGM31 - 1 WGM30 - 1
ICNC3 - 0 (unused) ICES3 - 0 (unused) WGM33 - 1 WGM32 - 1 CS32 - 0 CS31 - 0 CS 30 - 1
Fast PWM mode, prescaler of 1*/
Serial.println("Enter the value you want. 0->100 gives you B's target in mm, 101->200 gives you C's target (subtract 100 from the entered value).");
Serial.println("targetmmB spot 1");
if (0 < incomingByte <= 100)
targetmmB = incomingByte;
if (incomingByte > 100)
targetmmC = incomingByte - 100;
if (OCR3B <= 1994)
OCR3B = OCR3B + x;
//every 0.1s, if the target is bigger than the current value, increase PWM duty cycle
if (targetmmC > ((OCR3C+1)/20)){
if (millis()-timeoldC > 100)
if (OCR3C <= 1994)
OCR3C = OCR3C + x;
timeoldC = millis();
