Help with Serial GPS
Ok, so i bought a serial gps unit a while back from ebay for $12 shipped. Its been really cool to play with. I just soldered together the sparkfun rs232 shifter board and tested it out and now I have some problems that I cant seem to figure out. This is what I know:
1.GPS works with computer over usb to serial cable. (both raw serial output console and gps diagnostic programs show good data) :slight_smile:
  1. Raw serial data can be sent to arduino from usb to serial cable then to rs232 shifter board. All data is recieved perfectly. :slight_smile:
  2. When i hook the gps serial up to the rs232 shifter, nothing happens. No tx light on board and no data shown being recieved. :frowning:
  3. the gps specs are 12v power (cigarette lighter), 4800baud, standard NMEA sentences
  4. the only other monkeywrench that could be possible is the use of a male to male DB9 gender changer from radioshack in between shifter board and gps serial cable (both have female ends) RadioShack.com Official Site - America's Technology Store :-/
Im not really sure what to think or how to go about fixing this problem. any input or similar experience would be appreciated
anyone?
Have you tried to swap the tx and rx pins. see if cross connecting pins 2 and 3 going to the 9 pin connector solve the problem.
good luck
It is common for RS232 connections to need a null modem connection (pins 2 and 3 are cross connected instead of straight through) if the connector genders don't match. Try a null modem adapter (or cable) in place of your gender changer.
-j
thanks, that was exactly the problem. i dont have a null modem adapter but to test it i just wired it up in the null modem config and it works great!
