help with serproxy...?
Hello, is there a way to send hex code through serproxy?
I need to send 0d 0a, like when I press enter key on the key board. but I need to send it when I press a button on an adobe air application.
Thanks
It's a bit confusing what you want to do. The way I read it is that you want an adobe air application to send 0x0d, 0x0a to the arduino? If so you are on the wrong board
Alternatively if you want the arduino to send those bytes then:-
Serial.print(0x0d, BYTE);
Serial.print(0x0a, BYTE);
will do it.
Thanks, I am not using arduino I just wonder if you guys know any thing about serproxy. like sending hex code direct. or send something like "\r\n" would be translated to 0x0d 0x0a.
thanks
