Hi i'm new to all this but downloaded a bit of code for some relays that work with Alexa.
My Question is how and where do i put the code to add a servo to it?
here is the code please help
#include <ESP8266WiFi.h>
#include <ESP8266WebServer.h>
#include <WiFiUdp.h>
#include
#include "switch.h"
#include "UpnpBroadcastResponder.h"
#include "CallbackFunction.h"
// prototypes
boolean connectWifi();
//on/off callbacks
void Relay1On();
void Relay1Off();
void Relay2On();
void Relay2Off();
void Relay3On();
void Relay3Off();
void Relay4On();
void Relay4Off();
// Change this before you flash
const char* ssid = "PC-Wireless";
const char* password = "password123";
boolean wifiConnected = false;
UpnpBroadcastResponder upnpBroadcastResponder;
Switch *relay1 = NULL;
Switch *relay2 = NULL;
Switch *relay3 = NULL;
Switch *relay4 = NULL;
pinMode (D1, OUTPUT);
pinMode (D2, OUTPUT);
pinMode (D3, OUTPUT);
pinMode (D4, OUTPUT);
digitalWrite (D1,HIGH);
digitalWrite (D2,HIGH);
digitalWrite (D3,HIGH);
digitalWrite (D4,HIGH);
// Initialise wifi connection
wifiConnected = connectWifi();
if(wifiConnected){
upnpBroadcastResponder.beginUdpMulticast();
// Define your switches here. Max 14
// Format: Alexa invocation name, local port no, on callback, off callback
relay1 = new Switch("Relay 1", 80, Relay1On, Relay1Off);
relay2 = new Switch("Relay 2", 81, Relay2On, Relay2Off);
relay3 = new Switch("Relay 3", 82, Relay3On, Relay3Off);
relay4 = new Switch("Relay 4", 83, Relay4On, Relay4Off);
Serial.println("Adding switches upnp broadcast responder");
upnpBroadcastResponder.addDevice(*relay1);
upnpBroadcastResponder.addDevice(*relay2);
upnpBroadcastResponder.addDevice(*relay3);
upnpBroadcastResponder.addDevice(*relay4);
if(wifiConnected){
upnpBroadcastResponder.serverLoop();
relay1->serverLoop();
relay2->serverLoop();
relay3->serverLoop();
relay4->serverLoop();
void Relay1On() {
Serial.print("Switch Relay 1 turn on ...");
digitalWrite (D1,LOW);
void Relay1Off() {
Serial.print("Switch Relay 1 turn off ...");
void Relay2On() {
Serial.print("Switch Relay 2 turn on ...");
digitalWrite (D2,LOW);
void Relay2Off() {
Serial.print("Switch Relay 2 turn off ...");
digitalWrite(D2,HIGH);
void Relay3On() {
Serial.print("Switch Relay 3 turn on ...");
digitalWrite (D3,LOW);
void Relay3Off() {
Serial.print("Switch Relay 3 turn off ...");
void Relay4On() {
Serial.print("Switch Relay 4 turn on ...");
digitalWrite (D4,LOW);
void Relay4Off() {
Serial.print("Switch Relay 4 turn off ...");
digitalWrite(D4,HIGH);
// connect to wifi โ returns true if successful or false if not
boolean connectWifi(){
boolean state = true;
int i = 0;
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
Serial.println("");
Serial.println("Connecting to WiFi");
// Wait for connection
Serial.print("Connecting ...");
Serial.print(".");
if (i > 10){
state = false;
i++;
if (state){
Serial.println("");
Serial.print("Connected to ");
Serial.println(ssid);
Serial.print("IP address: ");
else {
Serial.println("");
Serial.println("Connection failed.");
return state;
please can some one show me where and what to put so a servo can open and close when i ask alexa
many thanks
