Help with servo speed control?
I came across ‘Ramp.h’ on Github and though it could be useful in controlling the position and speed of a servo when combined with the PWMServo driver.
My knowledge of C+ is quite limited so I would be very grateful on some guidance as to why the code below will not function?
Many thanks.
#include <Ramp.h>
int x;
unsigned long time_now = 0;
unsigned long time_start = 0;
bool target_reached = false;
int target = 100;
int duration = 1000;
rampInt myRamp;
  time_start = millis();
  myRamp.go(target, duration);  //Start ramping up to target through our defined duration
  x = myRamp.update();           // Get the current position
  Serial.println(x);
  if (x == target) {             // if target is reached print out duration and set target_reached flag to true
    time_now = millis();
    Serial.println("Target reached");
    Serial.println(x);
    Serial.print(time_now - time_start);
    Serial.print(" milli seconds");
    target_reached = true;   // Target has now been reached, stop printing out to Serial
Because time_start and myRamp.go() are done everytime round loop()? Put those two lines in setup() perhaps?
Its C++, not C+.
What I need to do is to repeatedly update the the ramp settings with new 'target' and 'durations' which I cant do if its in the 'setup'? Thanks for your help.
