Help with Shift register and 7 segment 4 digit display
Hi everyone
I'm currently trying to use the SN74HC595 shift register to interface it with a 7 segment 4 digit display. I'm trying to cycle through each digit with a number corresponding to the digit. The problem is for some reason my code only works for number 1 and 4, while most number simply doesn't work or flicker a little bit. I noticed that the number 1 and 4 in my circuit and code starts with a 0 bit (eg. 1 is B01100000) and numbers that doesn't work starts with a 1 bit (eg. 2 is B11011010). If I change the first bit to 0 (eg. change 2 to B01011010), the number displays properly except for the top (A) segment. I'm using the circuit given by this website: http://osoyoo.com/wp-content/uploads/2017/08/4dss-74hc595-fritzing.jpg , but I'm using a different code. Here is my code:
int clk = 6;
int latch = 5;
int data = 4;
int CAS[4] = {12, 11, 10, 9};
byte numbers[10] {B11111100, B01100000, B11011010, B11110010, B01100110, B10110110, B10111110, B11100000, B11111110, B11110110};
  pinMode(CAS[0], OUTPUT);
  pinMode(CAS[1], OUTPUT);
  pinMode(CAS[2], OUTPUT);
  pinMode(CAS[3], OUTPUT);
  pinMode(clk, OUTPUT);
  pinMode(latch, OUTPUT);
  pinMode(data, OUTPUT);
  digitalWrite(CAS[0], HIGH);
  digitalWrite(CAS[1], HIGH);
  digitalWrite(CAS[2], HIGH);
  digitalWrite(CAS[3], HIGH);
void loop(){
  for (int i=0; i<4; i++)
    digitalWrite(latch, LOW);
    shiftOut(data, clk, LSBFIRST, numbers[i+1]);
    digitalWrite(latch, HIGH);
    digitalWrite(CAS[i], LOW);
    digitalWrite(CAS[i], HIGH);
I've checked all other numbers, and since all of them (except 1 and 4) starts with a 1 bit, none of them works, unless I change the first bit to 0.
Any help would be greatly appreciated
Thanks
I'd guess an error in the circuit. If you forget the connection 13 to GND this might be the result (floating pin getting a slight voltage from the neighbor pin QA). Check your circuit if is exactly like the one you posted a link to.
