Help with Sim900A module with and MFRC522 rfid Reader Project
Hi, I need help using the Sim900A module with and MFRC522 rfid.
I have the MFRC522 rfid code working fine and the Sim900A code also working fine (codes shown below)
Th task now is to embed both together such that I can know via SMS that the door is opened.
Working Code to send SMS
#include "SIM900.h"
#include <SoftwareSerial.h>
//If not used, is better to exclude the HTTP library,
//for RAM saving.
//If your sketch reboots itself proprably you have finished,
//your memory available.
//#include "inetGSM.h"
//If you want to use the Arduino functions to manage SMS, uncomment the lines below.
#include "sms.h"
SMSGSM sms;
//To change pins for Software Serial, use the two lines in GSM.cpp.
//GSM Shield for Arduino
//www.open-electronics.org
//this code is based on the example of Arduino Labs.
//Simple sketch to send and receive SMS.
int numdata;
boolean started=false;
char smsbuffer[160];
char n[20];
     //Serial connection.
     Serial.println("GSM Shield testing.");
     //Start configuration of shield with baudrate.
     //For http uses is raccomanded to use 4800 or slower.
     if (gsm.begin(2400)) {
          Serial.println("\nstatus=READY");
          started=true;
     } else Serial.println("\nstatus=IDLE");
     if(started) {
          //Enable this two lines if you want to send an SMS.
          if (sms.SendSMS("+1234567890", "Door Access Granted "))
          Serial.println("\nSMS sent OK");
     if(started) {
          //Read if there are messages on SIM card and print them.
          if(gsm.readSMS(smsbuffer, 160, n, 20)) {
               Serial.println(n);
               Serial.println(smsbuffer);
Any Assistance would be highly appreciated.
Thanks
RFID.txt (20 KB)
