help with simple array
Hello,
I just wrote a small program as you see:
int filaLuci [] = {13, 9, 10};
void setup()  {
 for (int i=0; i<3; i++)
 pinMode (filaLuci [i], OUTPUT);
 digitalWrite (filaLuci [ 0 ], HIGH);
 delay (1000);
 digitalWrite (filaLuci [ 0 ], LOW);
 delay (1000);
 digitalWrite (filaLuci [ 1 ], HIGH);
 digitalWrite (filaLuci [ 2 ], HIGH);
 delay (1000);
 digitalWrite (filaLuci [ 1 ], LOW);
 digitalWrite (filaLuci [ 2 ], LOW);
 delay (1000);
I want to know if there is the possibility to activate the 1 and 2 pins in the same digitalWrite line. I did try with:
[/code]
digitalWrite (filaLuci [ 1, 2 ], HIGH);
[/code]
but it does not work.
any suggestion?
thank you
matteo
Not with digitalWrite, no.
But you could maybe look at direct port manipulation, but it won't be as simple or as portable.
