Help with simple PWM
hello everyone, I modified a simple PWM code where the user can define freq and dutycycle. see code below. It does not work. I think it is something to with the delayMicroseconds command. I put in a number for the delayMicroseconds command and it works fine. But when I put in the timeOn variable it does not work.
Any suggestions would be appreciated Thankyou
// pwm where user defines output freq and duty cyle int dutyCycle=0.20; //user defined int outFreq=.002000; //user defined in megahertz int period=1/outFreq; int timeOn=dutyCycle*period; int timeOff=period-timeOn;
void setup() { pinMode(8,OUTPUT);
void loop() { digitalWrite(8,HIGH);
delayMicroseconds(timeOn); //time the led is on.
digitalWrite(8,LOW);
delayMicroseconds(timeOff); }
This is always 0 (zero). You cannot use integers and calculate with floating points.
Sure it does. It just doesn't do what you want.
So, dutyCycle is 0, as is outFreq.
Umm. It's really not a good idea to divide by 0.
So, timeOn is 0 times infinity, or 0. The timeOff is infinity minus 0, or infinity.
loop() then turns the pin on for 0 milliseconds, turns it off, and then takes a bit of time to end the function.
Is that not what you wanted?
Hello I wrote the following code for PWM but it isnt running. I am trying to get a PWM output at pin 11 and 3. I want a frequency of 100HZ.
I used Fout=Fclock/(2prescalerICR1) to calculate ICR1 value.
I used Dutycyle=OCRA1+1/timerMaxcount to calculate value for OCRA1.
Any help would be appreciated. Thanks
pinMode(11, OUTPUT);
pinMode(3,OUTPUT);
//set value of TCCR2A
//set values of TCCR2B
TCCR2B|=(WGM13<<1)|(CS11<<1);
//set output freq by setting ICR
//setting to 40.96 gives fout of 100hz
ICR1=40;
//set dutycycle by setting OCRA
OCR2A=32767;
Please do not cross-post. This wastes time and resources as people attempt to answer your question on multiple threads.
Threads merged.
Read this before posting a programming question
Please edit your post, select the code, and put it between [code][/code] tags.
You can do that by hitting the # button above the posting area.
  • Moderator
