I’ve got a system setup that reads a temp sensor, and depending on temp sensor readings it will move a servo. The problem I’m having is that the servo gets very jittery. How can I work the smoothing example into my code? I see the example just writes to serial output. Here is my code for my control:
// Controlling a servo position using a temperature sensor
// by Michal Rinott <http://people.interaction-ivrea.it/m.rinott>
// edited 5-12-2010 by Will Lyon to include base setting for servo if voltage not detected on pin 7
#include <Servo.h>
#define CONTROL 7
Servo myservo; // create servo object to control a servo
int temps = 0; // analog pin used to connect the temp sensor
int val; // variable to read the value from the analog pin
pinMode (CONTROL, INPUT); // sets the control pin to input
myservo.attach(9); // attaches the servo on pin 9 to the servo object
digitalWrite(CONTROL, LOW); // ensure internal pullup resistor is disabled.
val = digitalRead(CONTROL); //read input of pin 7 and store it
if (val == HIGH){ // reads whether or not 5v is present on pin 7, if 5v present, continue:
val = analogRead(temps); // reads the value of the temp sensor (value between 0 and 1023)
val = map(val, 350, 700, 75, 105); // scale it to use it with the servo (value between 0 and 180)
myservo.write(val); // sets the servo position according to the scaled value
delay(25); // waits for the servo to get there
if (val == LOW); // if no voltage present on pin 7, continue
myservo.write(50); //sets servo position to 50 if no voltage is detected on pin 7
Here is a link to my projects:
Fritzing setup: http://fritzing.org/projects/arduino-temperature-based-servo-control/
Worklog @ TheBestCaseScenario.com: TBCS Community Forums
Thanks in advance for the help!
