hi there!
I'm building an arcade machine based on 32x32 LED matrix,normally multiplexed:all rows are anode connected,all columns are cathode connected.
At the time my idea of controlling the screen is by Persistence Of Vision-switching the LED fast enough so it'll look like their all running at the same time. by doing so I've noticed the brightness of the LED's are not as strong as regular operation,I've read about TLC5940 and some other chips so i wanted to ask what is the best chip/other way the switching fast the state of the LED's without comprising on the brightness....probably there's a chip the can supply continuous voltage to LED's while being able to update them very quickly (1024 LED's,after all..)
I'm running Arduino Mega 2560 Rev3 btw...using currently almost every pin to control the LED's 8)
I tried to find similar question in earlier posts but i couldn't find one....
The trick is to give the LED a lot more current when it is on to compensate for the fact hat it is not on for very long.
However you have to make sure that the LEDs can stand such a pulse current and also that your drivers can stand this current. The down side is that if the multiplexing stops for any reason your LEDs and / or drivers burn out.
Then you will not be multiplexing them and so you need a lot of driver chips.
kimkash:
hi there!
I'd wire it as four separate 8x8 matrices and control it with four MAX7219 chips. That gives maximum 8:1 multiplexing with only a few Arduino pins.
I read a little about the MAX7219 and i want to ask-how do you control it serially? you keep sending commands for 8 slots which the chip updates and using current from external source of power and not the Arduino?
Mike I'll definitively not be using your suggestion with the LED drivers because my matrix is built from the 8x8 per-assembled LED matrix unit that can be easily found on eBay,so i can't risk burning LED nor chips nor LED drivers....I'm not that rich 8)
I understand basically the principle but if i have 16 pins to control on one chip-once i chain another does it act like a 32-output pin chip or does it act in another way?
It means you can string many of them together on one set of control lines.
So if you have two then you can drive two matrices, you can chain four together to give you a 16 by 16 but you need eight for 32 by 32.
The data sheet shows you how to do it.
In order to build matrix of size X by Y,i need a chip that can control positive current to X pins and a chip that can drain Y pins. is the MX7219 can do just the supply/drain jobs or both? In other words-in order to run 16X by 16Y matrix i need one chip of MAX7219 to control supply lines (=anodes) and one chip to control drain lines (=cathodes) or do i need one to control one of them and other chip to control the second type (supply/drain)?
kimkash:
And (hopefully) last question: is there a chip able to control more pins? What is the chip with biggest number
of control pins? Refering of course to LED matrix type of application...??
