Help with sprintf
Hey there,
iam trying to make some RTTY TX, and send some temperature info with it.
But i have some variable problem, when i try to send var.
This is the code:
#define RADIOPIN 13
#include <string.h>
#include <util/crc16.h>
#include <Wire.h>
int tmp102Address = 0x48;
char datastring[80];
char variabl;
int i1 = 0;
  pinMode(RADIOPIN,OUTPUT);
  Wire.begin();
  i1++;
  float celsius = getTemperature();
  sprintf(datastring, i1 + " data line;");// Puts the text in the datastring
  unsigned int CHECKSUM = gps_CRC16_checksum(datastring);  // Calculates the checksum for this datastring
  char checksum_str[6];
  sprintf(checksum_str, "*%04X\n", CHECKSUM);
  strcat(datastring,checksum_str);
  rtty_txstring (datastring);
  delay(2000);
float getTemperature(){
  Wire.requestFrom(tmp102Address,2);
  byte MSB = Wire.read();
  byte LSB = Wire.read();
  //it's a 12bit int, using two's compliment for negative
  int TemperatureSum = ((MSB << 8) | LSB) >> 4;
  float celsius = TemperatureSum*0.0625;
  return celsius;
void rtty_txstring (char * string)
  /* Simple function to sent a char at a time to
   	** rtty_txbyte function.
   	** NB Each char is one byte (8 Bits)
  char c;
  c = *string++;
  while ( c != '\0')
    rtty_txbyte (c);
    c = *string++;
void rtty_txbyte (char c)
  /* Simple function to sent each bit of a char to
   	** rtty_txbit function.
   	** NB The bits are sent Least Significant Bit first
   	** All chars should be preceded with a 0 and
   	** proceded with a 1. 0 = Start bit; 1 = Stop bit
  int i;
  rtty_txbit (0); // Start bit
  // Send bits for for char LSB first
  for (i=0;i<7;i++) // Change this here 7 or 8 for ASCII-7 / ASCII-8
    if (c & 1) rtty_txbit(1);
    else rtty_txbit(0);
    c = c >> 1;
  rtty_txbit (1); // Stop bit
void rtty_txbit (int bit)
  if (bit)
    // high
    digitalWrite(RADIOPIN, HIGH);
    // low
    digitalWrite(RADIOPIN, LOW);
  //                  delayMicroseconds(3370); // 300 baud
  delayMicroseconds(10000); // For 50 Baud uncomment this and the line below.
  delayMicroseconds(10150); // You can't do 20150 it just doesn't work as the
                            // largest value that will produce an accurate delay is 16383
                            // See : http://arduino.cc/en/Reference/DelayMicroseconds
uint16_t gps_CRC16_checksum (char *string)
  size_t i;
  uint16_t crc;
  uint8_t c;
  crc = 0xFFFF;
  // Calculate checksum ignoring the first two $s
  for (i = 2; i < strlen(string); i++)
    c = string[i];
    crc = _crc_xmodem_update (crc, c);
  return crc;
When i try to decode the RTTY, there is only “FFFF” decoded.
I think the problem is here:
how i can construct this datastring with vars?
Adding an "into" to a string pointer?sprintf(datastring,  "  %ddata line;", i1);
Thanks a lot!
