Help with Stair Lighting using HC-SR04 sensor and WS2812 LED Strip
Hi All
Excuse my naivete in this as I am very new to Arduino and the programming of. I am trying to put together a project for stair lighting triggered by a ultrasonic sensor at the bottom of the stairs and turned off by an ultrasonic sensor at the top of the stairs. I am using an WS2812 LED strip and have the lights travel up the stairs when going up and down when going down. I'm sure this is a project many of you have seen. I have searched the net and youtube and have found many examples of this project, none that I can find using the HC-SR04 sensor. I have managed to cobble together a code which works fine in one direction but am now stumped as how to get it to work the other way.
I would also like to add an LDR to the project so it is only active at night. If any of you can point me in the right direction I would be really grateful. I have attached the code so you can see where I am at.
#include <FastLED.h>
#define trigPin_up 2
#define echoPin_up 3
#define trigPin_down 4
#define echoPin_down 5
#define LED_PIN     7
#define NUM_LEDS    13
CRGB leds[NUM_LEDS];
  int tOn = 400; //LED On delay
  int tOff = 750; //LED Off delay
  int del = 0; //Delay after action (used for debugging - set to 500-1000 to introduce a delay between each action)
    //Set Serial
  Serial.println("");
  Serial.println("Activated");
  delay(del);
  FastLED.addLeds<WS2812, LED_PIN, GRB>(leds, NUM_LEDS);
  pinMode(trigPin_up, OUTPUT);
  pinMode(echoPin_up, INPUT);
  pinMode(trigPin_down, OUTPUT);
  pinMode(echoPin_down, INPUT);
   short duration, distance;
  digitalWrite(trigPin_up, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin_up, HIGH);
  delayMicroseconds(10);
  duration = pulseIn(echoPin_up, HIGH);
  distance = (duration/2) / 35.1;
  if (distance <= 50) {
  leds[0] = CRGB(255, 225, 255);
  FastLED.show();
  delay(100);
  leds[1] = CRGB(255, 255, 255);
  FastLED.show();
  delay(100);
  leds[2] = CRGB(255, 255, 255);
  FastLED.show();
  delay(100);
  leds[3] = CRGB(255, 255, 255);
  FastLED.show();
  delay(100);
  leds[4] = CRGB(255, 255, 255);
  FastLED.show();
  delay(100);
  leds[5] = CRGB(255, 255, 255);
  FastLED.show();
  delay(100);
  leds[6] = CRGB(255, 255, 255);
  FastLED.show();
   delay(100);
   leds[7] = CRGB(255, 255, 255);
  FastLED.show();
   delay(100);
   leds[8] = CRGB(255, 255, 255);
  FastLED.show();
   delay(100);
   leds[9] = CRGB(255, 255, 255);
  FastLED.show();
   delay(100);
   leds[10] = CRGB(255, 255, 255);
  FastLED.show();
   delay(100);
   leds[11] = CRGB(255, 255, 255);
  FastLED.show();
   delay(100);
   leds[12] = CRGB(255, 255, 255);
  FastLED.show();
   delay(100);
   leds[13] = CRGB(255, 255, 255);
  FastLED.show();
  delay(100);
{    short duration, distance;
  digitalWrite(trigPin_down, LOW);
  digitalWrite(trigPin_down, HIGH);
  duration = pulseIn(echoPin_down, HIGH);
  leds[0] = CRGB(0, 0, 0);
  FastLED.show();
  delay(100);
  leds[1] = CRGB(0, 0, 0);
  FastLED.show();
  delay(100);
  leds[2] = CRGB(0, 0, 0);
  FastLED.show();
  delay(100);
  leds[3] = CRGB(0, 0, 0);
  FastLED.show();
  delay(100);
  leds[4] = CRGB(0, 0, 0);
  FastLED.show();
  delay(100);
  leds[5] = CRGB(0, 0, 0);
  FastLED.show();
  delay(100);
  leds[6] = CRGB(0, 0, 0);
  FastLED.show();
   delay(100);
   leds[7] = CRGB(0, 0, 0);
  FastLED.show();
   delay(100);
   leds[8] = CRGB(0, 0, 0);
  FastLED.show();
   delay(100);
   leds[9] = CRGB(0, 0, 0);
  FastLED.show();
   delay(100);
   leds[10] = CRGB(0, 0, 0);
  FastLED.show();
   delay(100);
   leds[11] = CRGB(0, 0, 0);
  FastLED.show();
   delay(100);
   leds[12] = CRGB(0, 0, 0);
  FastLED.show();
   delay(100);
   leds[13] = CRGB(0, 0, 0);
  FastLED.show();
  delay(100);
Many thanks
#define NUM_LEDS    13
A thirteen element array has no element with the index 13.
Thanks. This is just a test set up at the moment. The final project will have around 200 LEDS so I will adjust the code to suit.
I've managed to put together a code that now works in both directions but it is intermittent in working. Sometimes the sensors work first time, other times you need to block them for a couple of seconds. Also you can't trigger either sensor straight after walking past it. here is the code so far
#define LED_PIN     7
#define NUM_LEDS    13
    //Set Serial
 void loop(){
 if (trigPin_up, HIGH && trigPin_down, LOW);
  distance = (duration/2) / 29.1;
  FastLED.show();
  delay(100);
  FastLED.show();
  delay(100);
  FastLED.show();
  delay(100);
  FastLED.show();
  delay(100);
  FastLED.show();
  delay(100);
  FastLED.show();
  delay(100);
  FastLED.show();
   delay(100);
  FastLED.show();
   delay(100);
  FastLED.show();
   delay(100);
  FastLED.show();
   delay(100);
  FastLED.show();
   delay(100);
  FastLED.show();
   delay(100);
  FastLED.show();
   delay(100);
  FastLED.show();
  delay(100);
  FastLED.show();
  delay(100);
  FastLED.show();
  delay(100);
  FastLED.show();
  delay(100);
  FastLED.show();
  delay(100);
  FastLED.show();
  delay(100);
  FastLED.show();
  delay(100);
  FastLED.show();
   delay(100);
  FastLED.show();
   delay(100);
  FastLED.show();
   delay(100);
  FastLED.show();
   delay(100);
  FastLED.show();
   delay(100);
  FastLED.show();
   delay(100);
  FastLED.show();
   delay(100);
  FastLED.show();
  delay(100);
if (trigPin_up, LOW && trigPin_down, HIGH);
  leds[13] = CRGB(255, 225, 255);
  FastLED.show();
  delay(100);
  FastLED.show();
  delay(100);
  FastLED.show();
  delay(100);
  FastLED.show();
  delay(100);
  FastLED.show();
  delay(100);
  FastLED.show();
  delay(100);
  FastLED.show();
   delay(100);
  FastLED.show();
   delay(100);
  FastLED.show();
   delay(100);
  FastLED.show();
   delay(100);
  FastLED.show();
   delay(100);
  FastLED.show();
   delay(100);
  FastLED.show();
   delay(100);
   leds[0] = CRGB(255, 255, 255);
  FastLED.show();
  delay(100);
  FastLED.show();
  delay(100);
  FastLED.show();
  delay(100);
  FastLED.show();
  delay(100);
  FastLED.show();
  delay(100);
  FastLED.show();
  delay(100);
  FastLED.show();
  delay(100);
  FastLED.show();
   delay(100);
  FastLED.show();
   delay(100);
  FastLED.show();
   delay(100);
  FastLED.show();
   delay(100);
  FastLED.show();
   delay(100);
  FastLED.show();
   delay(100);
  FastLED.show();
   delay(100);
  FastLED.show();
  delay(100);
Don't you just hate it when that happens?
I've removed the 13th element now but it's still only working every now and then. Is there a way of reading the value of the ultrasonic sensors because I think the following is wrong
Do you know what the comma operator does?
