help with stopwatch, Pushbutton, FSR
hi, im playing around the the stopwatch code on the site.
I want an FRS to activate and deactivate the stopwatch on the condition that a push button has been pressed 1st. (i.e standby switch)
the FSR is working atm. but the part of code i have added for the pushbutton has no effect.
if anyone could point me in the right direction mcuh appreciated
many thanks :slight_smile:
/* StopWatch
  • Paul Badger 2008
  • Demonstrates using millis(), pullup resistors,
  • making two things happen at once, printing fractions
  • Physical setup: momentary switch connected to pin 4, other side connected to ground
  • LED with series resistor between pin 13 and ground
#define ledPin 13 // LED connected to digital pin 13
#define fsrPin 2
#define buttonPin 4 // button on pin 4
int value = LOW; // previous value of the LED
int buttonState; // variable to store button state
int lastButtonState; // variable to store last button state
int fsrState; // variable to store button state
int lastfsrState;
int blinking; // condition for blinking - timer is timing
long interval = 100; // blink interval - change to suit
long previousmillis = 0; // variable to store last time LED was updated
long startTime ; // start time for stop watch
long elapsedTime ; // elapsed time for stop watch
// variable used to store fractional part of time
float t;
pinMode(ledPin, OUTPUT); // sets the digital pin as output
pinMode(fsrPin, INPUT); // not really necessary, pins default to INPUT anyway
analogWrite(fsrPin, HIGH); // turn on pullup resistors. Wire button so that press shorts pin to ground.
pinMode(buttonPin,INPUT);
digitalWrite (buttonPin, HIGH);
// check for button press
buttonState = digitalRead(buttonPin); // read the button state and store
fsrState = analogRead (fsrPin);
if (buttonState == LOW && lastButtonState == HIGH && fsrState == false){
Serial.print("press FSR!! ");
delay (1000);
lastButtonState = buttonState;
else if (buttonState == LOW && lastButtonState == HIGH && fsrState == true){
Serial.print("Ready!! ");
delay (1000);
if (fsrState == 0 && lastfsrState >= 1 && blinking == false){ // check for a high to low transition
// if true then found a new button press while clock is not running - start the clock
startTime = millis(); // store the start time
blinking = true; // turn on blinking while timing
delay(5); // short delay to debounce switch
lastfsrState = fsrState; // store fsrState in lastfsrState, to compare next time
else if (fsrState == 0 && lastfsrState >= 1 && blinking == true){ // check for a high to low transition
// if true then found a new button press while clock is running - stop the clock and report
elapsedTime = millis() - startTime; // store elapsed time
blinking = false; // turn off blinking, all done timing
lastfsrState = fsrState; // store buttonState in lastButtonState, to compare next time
// routine to report elapsed time
Serial.print("Time: ");
Serial.print("\t");
Serial.println( (int)(elapsedTime)); // divide by 1000 to convert to seconds - then cast to an int to print
t =((elapsedTime)/2.00); // print time divided by 2
Serial.print("t=");
Serial.println(t);
delay(5);
else{
// blink routine - blink the LED while timing
// check to see if it's time to blink the LED; that is, the difference
// between the current time and last time we blinked the LED is larger than
// the interval at which we want to blink the LED.
if ( (millis() - previousmillis > interval) ) {
if (blinking == true){
previousmillis = millis(); // remember the last time we blinked the LED
// if the LED is off turn it on and vice-versa.
if (value == LOW)
value = HIGH;
value = LOW;
digitalWrite(ledPin, value);
else{
digitalWrite(ledPin, LOW); // turn off LED when not blinking
Now, go click on "Modify", highlight all the code in your post, then click on the "#" (Code) button on the editor toolbar.
There.
Doesn't that look nicer?
(Not sure what a Financial Status Report will do for you, though)
Explain, please?
The chances of an analogRead actually returning the value zero (false) are not that good, unless the pin is solidly grounded.
