help with string concatenate
I am trying to concatenate a string
this is what I have for the string and it compiles
             String tempStr;
                char iptest = Ethernet.localIP();
                tempStr = "GET /es=led_on&ed=18&pld1=";
                tempStr = tempStr + iptest;
                tempStr = tempStr + " HTTP/1.1";
but when I ad this line to use the string
client.println(F(tempStr);
I get this when I try to compile
Arduino: 1.6.7 (Windows 7), Board: "Arduino Pro or Pro Mini, ATmega328 (5V, 16 MHz)"
WARNING: Category '' in library UIPEthernet is not valid. Setting to 'Uncategorized'
In file included from C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:28:0,
                 from sketch\arduino_with_ethernet_shield.ino.cpp:1:
C:\Users\Reg\Desktop\Arduino\arduino_with_ethernet_shield\arduino_with_ethernet_shield\arduino_with_ethernet_shield.ino: In function 'void loop()':
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/WString.h:38:74: error: initializer fails to determine size of '__c'
 #define F(string_literal) (reinterpret_cast<const __FlashStringHelper *>(PSTR(string_literal)))
C:\Users\Reg\Desktop\Arduino\arduino_with_ethernet_shield\arduino_with_ethernet_shield\arduino_with_ethernet_shield.ino:127:32: note: in expansion of macro 'F'
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/WString.h:38:74: error: array must be initialized with a brace-enclosed initializer
arduino_with_ethernet_shield:127: error: expected ')' before ';' token
/                 client.println(F(tempStr);
exit status 1
  enabled in File > Preferences.
Thanks,
yonu
client.println(F(tempStr)); //<<< also note that you are missing one of the closing ")" in your example
The F() macro pulls a string from flash memory where the program itself resides so you can’t alter it
remove the F( ) around the tempStr and see if it works
client.println(tempStr);
also note that you are missing the closing “)” in your example
thanks that did it I didn't even catch the missing )
Thanks,
yonu
