Help with stroing ac voltage into an array
Hello,
I am hoping someone can help me with a my code. I am inputting ac voltage into an analog input on the arduino and I am trying to take 64 samples from the ac wave and store it in an array. I am looking to start readying the sine wave at the 1.56 value as the wave is shifted to the positive axis and it goes from 0-3.2. Now I think I might be close but not quite there yet with the logic.
Thanks in advance. :slight_smile:
int readings[64]; // the readings from the analog input
int readingvalue =1.56; //the value of which the array should start storing samples
int inputPin = A0; // A0 is the input pin
pinMode(inputPin, INPUT);
for(int i=0; i <= 64; i++){
readings[64] = analogRead(inputPin);
if(i >= readingvalue){
readings*;*
_ Serial.println(readings*);_
_
delay(500);*_
The rule of thumb is to sample at least 2x the frequency of your signal (Nyquist Theorem).
So what is the frequency of your analog signal?
This puts the value into the 65th location of "readings[]" which does not even exist. Counting array entries starts with 0. You need to read up on arrays, but something like this will work:
for (int i=0;  i < 64; i++)
    readings[i] = analogRead(inputPin);
jremington:
I have 120 vac stepped down to 1.55vrms and 4.4v peak to peak. output to my arduino with a DC offset of 2.2volts. Frequency is 60hz.
I'm multiplying voltage by current to read power and want to read the incoming voltage and multiply it by the current.
I see other people already helped you with your array indexing problem.
TomorrowsWorld:
This line shows you don't understand what values the analogRead() function returns, however. They are "int"s, or integers that can not contain decimal numbers like 1.56.
Normally an Arduino int can have any value between 0-65535 because it is 16bits long. In the case of analogRead(), however, it is returning a 10bit number that can range between 0-1023.
The method to convert an analog value in volts to the analogRead() value is analog_voltage/5V1023 (for example, 1.56/5V1023= 319).
BigBobby:
Nope.
An Arduino "int" is a signed sixteen bit value, so stores values between -32768 and +32767.
AWOL:
Nope.
Lol...yup, good catch.
BTW - you'll soon be needing a 16th bit to contain your post count.
yep, unsigned int to get to 65535.
float Voltage = A5;
//int vvalue=0;
long int Vtest[64];
for(int i =0; i < 64; i++){
Vtest = analogRead(A5);
  • //vvalue = analogRead(A5);*
    _ //float test = (vvalue/5)*1023;_
_ Serial.println(Vtest*);_
_
delay(500);_
_
}_
_
}*_
This is what I have so far. I think now I somehow have to use TTRCO and OCRA to get the exact time of one cycle of my sin wave and then compare that to my voltage into my arduino which is 1.55vrms don't I?
Sorry for posting to much guys, we were never taught arduino in school and my teacher asked me to do this project, so the only help I can find is in the forums. It's all a new language to me. Even when I understand what I'm trying to do I can't even type in the code correctly to accomplish what I want. It's very frustrating.
TomorrowsWorld:
Completely false. There is a galaxy of information about Arduino programming on the internet.
aarg:
Yes but it's hard to understand what im looking at.
This is the only place i can ask specific questions are get feedback
