Help with taming Accelerometers
Yep, fair point - I've not made it easier in uploading both sketches.
I've re-uploaded the one I'm using currently, along with a shot of the serial monitor. There is some other stuff going on in there, but the section which relates to the accelerometers is near the top. At the moment, they're just using 'Serial.print', and I think that maybe where I am getting stuck with trying to incorporate your suggestion - I'm sure its the way I should be doing it, but I've not defined any measurements as such...
#include <Adafruit_CircuitPlayground.h>
#include <Wire.h>
#include <SPI.h>
#include <math.h>
float X, Y, Z; // Accelerometers.
#define CLICKTHRESHHOLD 80 // Tap Threshold
#define MIC_PIN         A4  // Microphone is attached to this analog pin (A4 for circuit playground)
#define SAMPLE_WINDOW   10  // Sample window for average level
#define PEAK_HANG       24  // Time of pause before peak dot falls
#define PEAK_FALL        4  // Rate of falling peak dot
#define INPUT_FLOOR     10  // Lower range of analogRead input
#define INPUT_CEILING  500  // Max range of analogRead input, the lower the value the more sensitive (1023 = max)
byte peak = 16;        // Peak level of column; used for falling dots
unsigned int sample;
byte dotCount = 0;     //Frame counter for peak dot
byte dotHangCount = 0; //Frame counter for holding peak dot
float fscale(float originalMin, float originalMax, float newBegin, float newEnd, float inputValue, float curve);
void setup(void) {
  while (!Serial);
  CircuitPlayground.begin();
  CircuitPlayground.setAccelRange(LIS3DH_RANGE_8_G);   // TAPS (2/4/8/16)
  CircuitPlayground.setAccelTap(1, CLICKTHRESHHOLD);
  attachInterrupt(digitalPinToInterrupt(CPLAY_LIS3DH_INTERRUPT), tapTime, FALLING);
void tapTime(void) {
  // do something :)
   Serial.print(" High ");
   Serial.println(" ");
  X = CircuitPlayground.motionX();
  Y = CircuitPlayground.motionY();
  Z = CircuitPlayground.motionZ();
  Serial.print(" ");
  Serial.print(X);
  Serial.print(" ");
  Serial.print(Y);
  Serial.print(" ");
  Serial.println(Z);
    delay(100);
  int numPixels = CircuitPlayground.strip.numPixels();
  unsigned long startMillis= millis();  // Start of sample window
  float peakToPeak = 0;   // peak-to-peak level
  unsigned int signalMax = 0;
  unsigned int signalMin = 1023;
  unsigned int c, y;
  // collect data for length of sample window (in mS)
  while (millis() - startMillis < SAMPLE_WINDOW)
    sample = analogRead(MIC_PIN);
    if (sample < 1024)  // toss out spurious readings
      if (sample > signalMax)
        signalMax = sample;  // save just the max levels
      else if (sample < signalMin)
        signalMin = sample;  // save just the min levels
  peakToPeak = signalMax - signalMin;  // max - min = peak-peak amplitude
  // Serial.println(peakToPeak);
  //Fill the strip with rainbow gradient
  for (int i=0;i<=numPixels-1;i++){
    CircuitPlayground.strip.setPixelColor(i,Wheel(map(i,0,numPixels-1,30,150)));
  //Scale the input logarithmically instead of linearly
  c = fscale(INPUT_FLOOR, INPUT_CEILING, numPixels, 0, peakToPeak, 2);
  // Turn off pixels that are below volume threshold.
  if(c < peak) {
    peak = c;        // Keep dot on top
    dotHangCount = 0;    // make the dot hang before falling
  if (c <= numPixels) { // Fill partial column with off pixels
    drawLine(numPixels, numPixels-c, CircuitPlayground.strip.Color(0, 0, 0));
  // Set the peak dot to match the rainbow gradient
  y = numPixels - peak;
  CircuitPlayground.strip.setPixelColor(y-1,Wheel(map(y,0,numPixels-1,30,150)));
  CircuitPlayground.strip.show();
  // Frame based peak dot animation
  if(dotHangCount > PEAK_HANG) { //Peak pause length
    if(++dotCount >= PEAK_FALL) { //Fall rate
      peak++;
      dotCount = 0;
  else {
    dotHangCount++;
//Used to draw a line between two points of a given color
void drawLine(uint8_t from, uint8_t to, uint32_t c) {
  uint8_t fromTemp;
  if (from > to) {
    fromTemp = from;
    from = to;
    to = fromTemp;
  for(int i=from; i<=to; i++){
    CircuitPlayground.strip.setPixelColor(i, c);
float fscale( float originalMin, float originalMax, float newBegin, float
newEnd, float inputValue, float curve){
  float OriginalRange = 0;
  float NewRange = 0;
  float zeroRefCurVal = 0;
  float normalizedCurVal = 0;
  float rangedValue = 0;
  boolean invFlag = 0;
  // condition curve parameter
  // limit range
  if (curve > 10) curve = 10;
  if (curve < -10) curve = -10;
  curve = (curve * -.1) ; // -
  curve = pow(10, curve); //
  // Check for out of range inputValues
  if (inputValue < originalMin) {
    inputValue = originalMin;
  if (inputValue > originalMax) {
    inputValue = originalMax;
  // Zero Refference the values
  OriginalRange = originalMax - originalMin;
  if (newEnd > newBegin){
    NewRange = newEnd - newBegin;
    NewRange = newBegin - newEnd;
    invFlag = 1;
  zeroRefCurVal = inputValue - originalMin;
  normalizedCurVal  =  zeroRefCurVal / OriginalRange;   // normalize to 0 - 1 float
  // Check for originalMin > originalMax  - the math for all other cases i.e. negative numbers seems to work out fine
  if (originalMin > originalMax ) {
    return 0;
  if (invFlag == 0){
    rangedValue =  (pow(normalizedCurVal, curve) * NewRange) + newBegin;
  else     // invert the ranges
    rangedValue =  newBegin - (pow(normalizedCurVal, curve) * NewRange);
  return rangedValue;
uint32_t Wheel(byte WheelPos) {
  if(WheelPos < 85) {
    return CircuitPlayground.strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
  else if(WheelPos < 170) {
    WheelPos -= 85;
    return CircuitPlayground.strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
  else {
    WheelPos -= 170;
    return CircuitPlayground.strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
