Ok so I can't program to save my life. I'm good with hardware. And I know this can be done but I can't design it. Here the project.
I have a window fan that I run when it's cool outside, to save money. I'd like to automate its operation. So what I want is to have 2 thermometers, one inside and out outside. Then have it so that when the temperature inside is above 70 AND the temperature outside is under 65. Then a relay is activated letting 120vac threw to the fan.
I know this is super simple. It could be as easy as 2 thermocouples going from power to analog in. and 1 digital out controlling a relay. But I can't program to save my life.
I even have a parts list
Would anyone be willing to write the code and draw a circuit diagram? I'll pay $20 over pay pal for it. I know I'll have to tweek the code to get the temperatures right. But if you leave me comments in the code as to what variable to change and what kind of changes I should make to the variable. Then I can calibrate it. And I can solder just about anything if I have a basic line drawing. I'm NASA certified at soldering xD.
Uploading is easy for me. that's mostly hardware. And I can hardware just about anything. I've seen the how to's and I have the USB to serial on hand and I can wire it up easly.
