Help with TFT LCD 3.6" OR 3.5"
OK, I use this code :
where I need to change for 480X320?
 * generate testcard similar to BMP
#include <Adafruit_GFX.h>
#if defined(_GFXFONT_H_)           //are we using the new library?
#include <Fonts/FreeSans9pt7b.h>
#define ADJ_BASELINE 11            //new fonts setCursor to bottom of letter
#else
#define ADJ_BASELINE 0             //legacy setCursor to top of letter
#endif
#include <MCUFRIEND_kbv.h>
MCUFRIEND_kbv tft;
#define BLACK   0x0000
#define BLUE    0x001F
#define RED     0xF800
#define GREEN   0x07E0
#define CYAN    0x07FF
#define MAGENTA 0xF81F
#define YELLOW  0xFFE0
#define WHITE   0xFFFF
#define GREY    0x7BEF
#include <stdio.h>
uint16_t ID;
uint8_t hh, mm, ss; //containers for current time
uint8_t conv2d(const char* p)
    uint8_t v = 0;
    if ('0' <= *p && *p <= '9') v = *p - '0';
    return 10 * v + *++p - '0';
void setup(void)
    tft.reset();
    ID = tft.readID();
    Serial.print("TFT ID = 0x");
    Serial.println(ID, HEX);
    //    if (ID == 0x00D3) ID = 0x9481; // write-only shield
    if (ID == 0x00D3) ID = 0x9486; // write-only shield
    tft.begin(ID);
    tft.setRotation(1);
    tft.fillScreen(BLACK);
    tft.setFont(&FreeSans9pt7b);
#endif
    hh = conv2d(__TIME__);
    mm = conv2d(__TIME__ + 3);
    ss = conv2d(__TIME__ + 6);
  //  To change aspect
uint8_t aspect;
char *aspectname[] = {
    "PORTRAIT", "LANDSCAPE", "PORTRAIT_REV", "LANDSCAPE_REV"
void loop(void)
    aspect = 3;                   //  To change aspect
    tft.setRotation(aspect);      //  To change aspect
    int16_t x, y, dx, dy, idx;
    uint16_t w, h, len, mask;
    uint16_t colors[8] = { BLACK, WHITE, YELLOW, CYAN, GREEN, MAGENTA, RED, BLUE };
    uint16_t height, width;
    width = tft.width();
    height = tft.height();
    tft.fillRect(0, 0, 7, 3, WHITE);
    tft.fillRect(313, 0, 7, 3, WHITE);
    tft.fillRect(0, 237, 7, 3, WHITE);
    tft.fillRect(313, 237, 7, 3, WHITE);
    for (y = 0, w = 18, h = 3; y < 240; y += 13 * w + h) {
        for (x = 25; x < 320 - 18; x += 2 * w) {
            tft.fillRect(x, y, w, h, WHITE);
    for (x = 0, w = 7, h = 18; x < 320; x += 17 * h + w) {
        for (y = 21; y < 240 - 18; y += 2 * h) {
    tft.fillRect(7, 3, 17 * 18, 13 * 18, GREY);
    for (x = 7, y = 0, w = 1, h = 240; x < 320; x += 18) {
    for (x = 0, y = 3, w = 320, h = 1; y < 240; y += 18) {
    tft.fillRect(26, 22, 17, 99, tft.color565(0, 128, 64));     //turq
    tft.fillRect(26, 120, 17, 99, tft.color565(255, 128, 192)); //pink
    tft.fillRect(44, 22, 17, 35, tft.color565(0, 128, 255));    //blue
    tft.fillRect(44, 184, 17, 35, tft.color565(255, 128, 64));  //orng
    tft.fillRect(260, 22, 17, 35, tft.color565(0, 128, 255));     //blue
    tft.fillRect(260, 184, 17, 35, tft.color565(255, 128, 64));  //orng
    tft.fillRect(278, 22, 17, 99, tft.color565(128, 128, 0));   //grn
    tft.fillRect(278, 120, 17, 99, tft.color565(128, 0, 255)); //purp
    for (dx = 111; dx > -111; dx--) {
        w = sqrt(111 * 111 - dx * dx);
        y = 120 - dx;
        dy = (y - 3) / 18;
        mask = 7;
        switch (dy) {
            case 0:
            case 1: idx = 1; len = 0; break;
            case 2: idx = 0; len = 0; break;
            case 3: idx = 0; len = 13; mask = 1; break;
            case 4:
            case 5: idx = 2; len = 38; break;
            case 6:
            case 7:
            case 8: idx = 0; len = 0; break;
            case 9: for (idx = 2; idx < 8; idx++) {
                    dy = 0xFF >> (7 - idx);
                    colors[idx] = tft.color565(dy, dy, dy);
            case 10: idx = 1; len = 0; break;
            case 11:
            case 12: colors[2] = YELLOW; idx = 2; len = 0; break;
        if (len == 0)
            tft.fillRect(160 - w, y, w * 2, 1, colors[idx]);
        else {
            if (mask == 1) idx = 1 + (w) / len;
            dy = w % len;
            for (x = 160 - w; x < 160 + w; idx++) {
                tft.fillRect(x, y, dy, 1, colors[idx & mask]);
                x += dy;
                if (x + len > 160 + w) dy = w % len;
                else dy = len;
    for (x = 72, y = 129, dx = 5, dy = 0; dx > 0; x += 2 * dx) {
        tft.fillRect(x, y, dx, 36, WHITE);
        dy += dx * 2;
        if (dy >= 36) {
            dy = 0;
            dx--;
    tft.fillRect(160 - 8, 5 * 18 + 3, 17, 3 * 18, BLACK);
    for (x = 3 * 18 + 7, y = 6 * 18 + 3, w = 1, h = 18; x < 160 + 108; x += 18) {
    tft.fillRect(160 - 108, 120, 108 * 2, 1, WHITE);
    tft.fillRect(160, 5 * 18 + 3, 1, 3 * 18, WHITE);
    tft.fillRect(108, 2 * 18 + 3, 6 * 18, 18, WHITE);
    //    tft.fillRect(108, 10 * 18 + 3, 6 * 18, 18, BLACK);
    tft.fillRect(160 - 8, 11 * 18 + 3, 17, 31, RED);
    tft.setCursor(160 - 36, 24 + ADJ_BASELINE);
    tft.setTextColor(BLACK);
    tft.setTextSize(1);
    tft.print("320x240");
    tft.setCursor(109, 43 + ADJ_BASELINE);
    tft.setTextSize(1);
    tft.print("ID=0x");
    tft.print(tft.readID(), HEX);
    tft.setTextColor(WHITE, BLACK);
    //    tft.setFont(NULL);
    //    tft.setTextSize(2);
    while (1) {
        if (++ss > 59) {
            ss = 0;
            mm++;
            if (mm > 59) {
                mm = 0;
                hh++;
                if (hh > 23) hh = 0;
        char buf[20];
        sprintf(buf, "%02d:%02d:%02d", hh, mm, ss);
        tft.setCursor(128, 187 + ADJ_BASELINE);
        tft.print(buf);
Thanks.
