Help with the code
I want to on/off a LED with this code with the "2" ArduDroid app (Hazim Bitar)
Can somebody help me?
#include <Servo.h>
#include <NewPing.h>
 PROJECT: ArduDroid
 PROGRAMMER: Hazim Bitar (techbitar at gmail dot com)
 DATE: Oct 31, 2013
 FILE: ardudroid.ino
 LICENSE: Public domain
#define START_CMD_CHAR '*'
#define END_CMD_CHAR '#'
#define DIV_CMD_CHAR '|'
#define CMD_DIGITALWRITE 10
#define CMD_ANALOGWRITE 11
#define CMD_TEXT 12
#define CMD_READ_ARDUDROID 13
#define MAX_COMMAND 20  // max command number code. used for error checking.
#define MIN_COMMAND 10  // minimum command number code. used for error checking.
#define IN_STRING_LENGHT 40
#define MAX_ANALOGWRITE 255
#define PIN_HIGH 3
#define PIN_LOW 2
String inText;
//motor 1
int motorOneA = 2;
int motorOneB = 4;
int speedPinA = 5; //Must be a PWM pin for speed control
// Motor 2
int motorTwoA = 7;
int motorTwoB = 8;
int speedPinB = 6;  //Must be a PWM pin for speed control
//Servo Stuff
Servo scanServo;
Servo servo1;
Servo servo2;
Servo clawRotate;
Servo claw;
int servoPosition = 1500;
int servoIncrement = 200;
//Led pins
int obstacleDetectedLED = 10;
int obstacleNotDetectedLED = 9;
  Serial.flush();
//Attach Servo objects to corresponding pin
  scanServo.attach(12);
  servo1.attach(15);
  servo2.attach(14);
  clawRotate.attach(16);
  claw.attach(17);
 //Set all Servos to Center position
  scanServo.writeMicroseconds(1500);
  servo1.writeMicroseconds(1500);
  servo2.writeMicroseconds(1500);
  clawRotate.writeMicroseconds(1500);
  claw.writeMicroseconds(1500);
  //Set LED pins to output
  pinMode(obstacleDetectedLED, OUTPUT);
  pinMode(obstacleNotDetectedLED, OUTPUT);
  Serial.flush();
  int ard_command = 0;
  int pin_num = 0;
  int pin_value = 0;
  char get_char = ' ';  //read serial
  // wait for incoming data
  if (Serial.available() < 1) return; // if serial empty, return to loop().
  // parse incoming command start flag
  get_char = Serial.read();
  if (get_char != START_CMD_CHAR) return; // if no command start flag, return to loop().
  // parse incoming command type
  ard_command = Serial.parseInt(); // read the command
  // parse incoming pin# and value
  pin_num = Serial.parseInt(); // read the pin
  pin_value = Serial.parseInt();  // read the value
  // 1) GET TEXT COMMAND FROM ARDUDROID
  if (ard_command == CMD_TEXT){
    inText =""; //clears variable for new input
    while (Serial.available())  {
      char c = Serial.read();  //gets one byte from serial buffer
      delay(5);
      if (c == END_CMD_CHAR) { // if we the complete string has been read
      else {
        if (c !=  DIV_CMD_CHAR) {
          inText += c;
          delay(5);
  // 2) GET digitalWrite DATA FROM ARDUDROID
  if (ard_command == CMD_DIGITALWRITE){
    if (pin_value == PIN_LOW) pin_value = LOW;
    else if (pin_value == PIN_HIGH) pin_value = HIGH;
    else return; // error in pin value. return.
    set_digitalwrite( pin_num,  pin_value);  // Uncomment this function if you wish to use
    return;  // return from start of loop()
  // 3) GET analogWrite DATA FROM ARDUDROID
  if (ard_command == CMD_ANALOGWRITE) {
    pin_value=map(pin_value, 0, 255, 500, 2400);   // Map MIN and MAX values for Pin_value varialbe to MIN and MAX servo positions
    if (pin_num==11){                               //Convert pin_num from Ardudroid to Actual pin of Servos
      pin_num==15;
  servo1.writeMicroseconds(pin_value);
    if (pin_num==10) {
      pin_num==14;
  servo2.writeMicroseconds(pin_value);
    if (pin_num==9) {
      pin_num==16;
  clawRotate.writeMicroseconds(pin_value);
    if(pin_num==6) {
    pin_num==17;
  claw.writeMicroseconds(pin_value);
    // add your code here
    return;  // Done. return to loop();
  // 4) SEND DATA TO ARDUDROID
  if (ard_command == CMD_READ_ARDUDROID) {
    // char send_to_android[] = "Place your text here." ;
    // Serial.println(send_to_android);   // Example: Sending text
    Serial.print(" Analog 0 = ");
    Serial.println(analogRead(A0));  // Example: Read and send Analog pin value to Arduino
// 2a) select the requested pin# for DigitalWrite action
void set_digitalwrite(int pin_num, int pin_value)
  switch (pin_num) {
  case 13:
                                                    //Forward
  digitalWrite(obstacleNotDetectedLED, HIGH);
  delay(250);
  digitalWrite(obstacleNotDetectedLED, LOW);
  analogWrite(speedPinA, 255);//Sets speed variable via PWM
digitalWrite(motorOneA, LOW);
digitalWrite(motorOneB, HIGH);
analogWrite(speedPinB, 255);//Sets speed variable PWM
digitalWrite(motorTwoA, HIGH);
digitalWrite(motorTwoB, LOW);
Serial.println("Forward"); // Prints out "Motor 1 Forward" on the serial monitor
Serial.println("   "); // Creates a blank line printed on the serial monitor
  case 12:
                                                    //Backward
  delay(250);
 digitalWrite(motorOneA, HIGH);
 digitalWrite(motorOneB, LOW);
 digitalWrite(motorTwoA, LOW);
 digitalWrite(motorTwoB, HIGH);
 Serial.println("Backward");
  case 11:
                                                  //Right
  delay(250);
 Serial.println("Right");
  case 10:
                                                   //Left
  delay(250);
 Serial.println("Left");
  case 9:
                                                  //Brakes
  delay(250);
  analogWrite(speedPinA, 0);
  analogWrite(speedPinB, 0);
  case 8:
                                            //increment the positions of the servo by the value of servo increment
    pinMode(8, OUTPUT);
   servoPosition += servoIncrement;
   servo1.writeMicroseconds(servoPosition);
   delay(10);
  case 7:
    pinMode(7, OUTPUT);
    servoPosition -= servoIncrement;
    delay(10);
  case 6:
    pinMode(6, OUTPUT);
    servoPosition +=servoIncrement;
    servo2.writeMicroseconds(servoPosition);
    delay(10);
  case 5:
    pinMode(5, OUTPUT);
    delay(10);
  case 4:
    pinMode(4, OUTPUT);
    clawRotate.writeMicroseconds(servoPosition);
    delay(10);
  case 3:
    pinMode(3, OUTPUT);
    delay(10);
  case 2:
  pinMode(2, OUTPUT);                            //not used
  digitalWrite(2, pin_value);
    // default:
    // if nothing else matches, do the default
    // default is optional
Antwort :
https://forum.arduino.cc/index.php?topic=389511.0
