HELP WITH THE CONNECTION OF A MPU6050 WITH AN ARDUINO
Hello,
I am trying to connect a module MPU6050 with an arduino. I know that I have to connect the module in the pins analog 4 and 5 because of the I2C. But I can´t use those pins because I have all the analog pins used, but I had read that I can also connect the module in the pins SPI. The problem is that I don´t know how??
Thanks for reading.
the MPU6050 supports both I2C and SPI interfaces
have a look at the Arduino SPI page
Ok, great. But my question is, Where I connect the pins SCL and SDA in the arduino if I want to use the SPI conection?!
SCL and SDA are used for I2C
SPI uses
MISO (Master In Slave Out) - The Slave line for sending data to the master,
MOSI (Master Out Slave In) - The Master line for sending data to the peripherals,
SCK (Serial Clock) - The clock pulses which synchronize data transmission generated by the master
SS (Slave Select) - the pin on each device that the master can use to enable and disable specific devices
on the UNO the pins are 11 (MOSI), 12 (MISO) and 13 (SCK) - each device has a seperate SS pin e.g. 10
