Help with the error messages
My code is giving errors.
I'm new to Arduino, pls help me
#include <IRremote.h>
const int RED = 7;
const int GREEN = 6;
const int BLUE = 5;
int RECV_PIN = 11;
IRrecv irrecv(RECV_PIN);
decode_results  results;
  pinMode (RED, OUTPUT); // Включить выходы
  pinMode (GREEN, OUTPUT);
  pinMode  (BLUE, OUTPUT);
  irrecv.enableIRIn();  // Start the receiver
  if (irrecv.decode(&results))  {
    Serial.println(results.value, HEX);
    irrecv.resume(); // Receive  the next value
    if (results.value, HEX == FF30CF); {
      analogWrite(RED, 255);
      analogWrite(BLUE, 0);
      analogWrite(GREEN, 0);
    else {
      if (results.value, HEX == FF18E7);{
        analogWrite(RED,0);
        analogWrite(GREEN, 255);
      else {
        analogWrite(RED, 0);
        analogWrite(BLUE,255);
Welcome to the forum
Please post the full error message, using code tags when you do
Where did you get this idea from? results.value, HEX
Further FF30CF is a variable because it starts with a letter. That should be 0xFF30CF.
Lastly that semi-colon does not belong there.
So that part of your code becomes
if (results.value == 0xFF30CF) {
Repeat for the other ones.
Whatever else might be wrong, the semicolon at the end of this line will mean that the code intended to be executed if the values match will be executed unconditionally
As to other problems, where is FF18E7 declared ?
What value are you actually trying to match ? Is it 0xFF18E7 by any chance ?
Is the syntax using HEX == actually valid ?
Have you looked at the examples that come with the library ?
error messages
C:\Users\user\Documents\Arduino\notDone_-_IR_-_RGB\notDone_-_IR_-_RGB.ino:2:15: error: 'FF30CF' was not declared in this scope
 const int R = FF30CF
C:\Users\user\Documents\Arduino\notDone_-_IR_-_RGB\notDone_-_IR_-_RGB.ino: In function 'void setup()':
C:\Users\user\Documents\Arduino\notDone_-_IR_-_RGB\notDone_-_IR_-_RGB.ino:15:12: error: 'RED' was not declared in this scope
C:\Users\user\Documents\Arduino\notDone_-_IR_-_RGB\notDone_-_IR_-_RGB.ino: In function 'void loop()':
C:\Users\user\Documents\Arduino\notDone_-_IR_-_RGB\notDone_-_IR_-_RGB.ino:27:19: error: 'RED' was not declared in this scope
C:\Users\user\Documents\Arduino\notDone_-_IR_-_RGB\notDone_-_IR_-_RGB.ino:33:19: error: 'RED' was not declared in this scope
C:\Users\user\Documents\Arduino\notDone_-_IR_-_RGB\notDone_-_IR_-_RGB.ino:38:21: error: 'RED' was not declared in this scope
exit status 1
Compilation error: 'FF30CF' was not declared in this scope
code (updated)
const int G = FF18E7
const int RED = 7;
const int BLUE = 5;
int RECV_PIN = 11;
    else {
      if (results.value == 0xFF18E7) {
      else {
oh i fixed it
Please post the fixed code
