help with the if syntax
ok so i made a program and i need help corecting the if syntax in it
#include <TimeLib.h>
#include <Wire.h>
LiquidCrystal_I2C lcd(0x3F, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
lcd.begin(20,4);
// setTime(hr,min,sec,day,month,yr);
setTime(12,0,0,31,12,2015);
pinMode(8,OUTPUT);
pinMode(7,OUTPUT);
digitalWrite(8,HIGH);
// round(analogRead(0) / 100 menu control value 0-10
if (round(analogRead(0) / 100 == 1)
{ // the error line is this one
lcd.setCursor(6,0);
lcd.print(hourFormat12());
lcd.print(":");
if ( minute() < 10 ) {
lcd.print(“0”);
lcd.print(minute());
lcd.print(":");
if ( second() < 10 ) {
lcd.print(“0”);
lcd.print( second());
lcd.print(" ");
lcd.setCursor(6,1);
lcd.print( round(analogRead(0) / 100));
delay(120);
// lcd.clear();
lcd.clear();}
here is the error
Arduino: 1.6.8 Hourly Build 2015/12/30 06:43 (Windows 10), Board: “Arduino/Genuino Uno”
C:\Users\brenden\Documents\Arduino\best_clock_code\best_clock_code.ino: In function ‘void loop()’:
best_clock_code:22: error: expected ‘)’ before ‘{’ token
best_clock_code:45: error: expected primary-expression before ‘}’ token
best_clock_code:45: error: expected ‘;’ before ‘}’ token
exit status 1
“Show verbose output during compilation”
enabled in File > Preferences.
To get help, you must show us your complete sketch. Attach your code using the </> icon on the left side of the posting menu.
Do your brackets/braces match up?
that helped ... i fixed the brackets now it works thank you larry!
using CTRL-T does an auto indent which helps to get brackets-count right
