Help with the LiquidCrystal Class
Hey guys
I’m trying to use two LiquidCrystal objects in another class, and I can’t figure out what’s wrong with the code, I attached the code, as well as the full error trace.
//Main
#include "test.h"
#include <LiquidCrystal.h>
LiquidCrystal lcd(12,10,5,4,3,2);
LiquidCrystal lcd2(12,10,5,4,3,2);
Display2 dd(&lcd,&lcd2);
//--------------------------MAIN----------------------------------------
//test.h
#include <Arduino.h>
class Display2{
private:
LiquidCrystal* lcd;
LiquidCrystal* lcd2;
public:
Display2(LiquidCrystal* aLCD,LiquidCrystal* bLCD) : lcd(aLCD), lcd2(bLCD)
void show(int display_code);
//test.cpp
#include "test.h"
Display2(LiquidCrystal* aLCD, LiquidCrystal* bLCD) : lcd(aLCD), lcd2(bLCD)
    lcd->begin(16,2);
    lcd2->begin(16,2);
void Display2 :: show(int display_code){
      if(display_code = 0){
          lcd->print("Boot Test1");
          lcd2->print("Boot Test2");
          lcd->clear();
          lcd2->clear();
          lcd->print("Ready");
          lcd2->print("Ready");
          lcd->clear();
          lcd2->clear();
      else if(display_code = 1){
      else if(display_code = 2){
      else if(display_code = 3){
Full error trace
test.cpp:5:23: error: expected ')' before '*' token
test.cpp:36:1: error: expected declaration before '}' token
exit status 1
You've defined your Display2 constructor code twice - once in the .h file and once (incorrectly, no scope specifier) in the .cpp file. Choose one. Might be other mistakes, but fix that first.
yes he is correct
