Help with the MenuBackend library
I can't fully understand how to use this library. I'm trying to reverse engineer sample code, but I'm not having much luck. I want to create an menu system for an LCD with a 4x4 keypad as input. I think I understand the keypad library (it doesn't seem to hard). The sending messages with the liquid crystal library isn't too bad either. I can't wrap my head around how to go about using the MenuBackend library and documentation on it in the playground is very poor. I also am not very sure on how to manipulate the cursor to select an item.
#include <LiquidCrystal.h>
#include <Keypad.h>
#include <Time.h>
#include <MenuBackend.h>
LiquidCrystal lcd(12, 10, 5, 4, 3, 2);
const byte ROWS = 4; //Four rows
const byte COLS = 4; //Four columns
static char key;
char KEYS[ROWS][COLS] = {
  {'1','2','3','A'},
  {'4','5','6','B'},
  {'7','8','9','C'},
  {'*','0','#','D'}
}; //Defines the buttons
byte ROWpins[ROWS]={2,3,4,5}; //connect the row pins
byte COLpins[COLS]={6,7,8,9}; //connect the column pins
Keypad KEYPAD = Keypad(makeKeymap(KEYS), ROWpins, COLpins, ROWS, COLS);
//Setting up the menu
MenuBackend menu = MenuBackend(menuUsed,menuChanged);
  MenuItem menuItem1 = MenuItem("Item1");
   MenuItem menuItem1SubItem1 = MenuItem("Item1subItem1");
   MenuItem menuItem1SubItem2 = MenuItem("Item1subItem2");
  MenuItem menuItem2 = MenuItem("Item2");
   MenuItem menuItem2SubItem1 = MenuItem("Item2subItem1");
   MenuItem menuItem2SubItem2 = MenuItem("Item2subItem2");
   MenuItem menuItem2SubItem3 = MenuItem("Item2subItem3");
  MenuItem menuItem3 = MenuItem("Item3");
 lcd.begin(16, 2);
 menu.getRoot().add(menuItem1);
 menuItem1.addRight(menuItem2).addRight(menuItem3);
 menuItem1.add(menuItem1SubItem1).addRight(menuItem1SubItem2);
 menuItem2.add(menuItem2SubItem1).addRight(menuItem2SubItem2).addRight(menuItem2SubItem3);
menu.toRoot();
lcd.setCursor(0,0);
  lcd.print("hello, world!");
  key = KEYPAD.getKey(); // Gets the key that was used.
  if(key != NO_KEY) //I think it's test code.
  Serial.println(key);
void menuUsed(MenuUseEvent used){
void navigateMenus(){}
 void menuChanged(MenuChangeEvent changed) {
Can someone point me in the right direction on this?
EDIT: I am using a 16x2 RGB LCD and a 4x4 arduino compatible keypad. Also, ignore the pin locations between the lcd and keypad. I don't even have the keypad in yet, so I'm hoping to get a start on the menu system while I'm waiting for it.
Derkatwork:
Here's a link to another forum post where AlphaBeta is answering questions and fixing problems. http://arduino.cc/forum/index.php/topic,38053.0.html
It looks like a good place to get a deeper understanding of how his menu system works.
I would like to change menu titles dynamically during program execution. I want the name of a menu item to change from "start" to "stop" depending on the state of the program. How can I do this? I see getname but no setname.
