I am a bit inexperienced with C++ and the arduino and still trying to get to grips with it.
After the standard MPU6050_DMP6 example which accompanies the i2cdev library froze repeatedly after a couple of seconds, I finally discovered the SIMPLE_MPU6050 library, which works just great for my experiment. However I need some help with it.
I have a few questions regarding this library:
In which file can I change the sensitivity levels of the gyro and accelerometer, i.e the ranges of 2 - 16 g and turn rates of 250deg-2000deg/sec etc.
Similar to the ability of the MPU6050_DMP6 example program to output data for the Processing Tea Pot example, how can the code of the SIMPLE_MPU6050 library be modified to do the same.
Your duplicate topic, posted in a totally inappropriate forum section, has been deleted
Cross-posting is against the rules of the forum. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend 15 minutes (or more) writing a detailed answer on this topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting will result in a timeout from the forum.
In the future, please take some time to pick the forum board that best suits the topic of your question and then only post once to that forum board. This is basic forum etiquette, as explained in the sticky "How to use this forum - please read." post you will find at the top of every forum board. It contains a lot of other useful information. Please read it.
