Hi ( Still newbie in Programing here )
I am making a project with the use of an arduino pro mini and oled SSD1306 128X64 display
i am using the U8glib library
my project aims to display the voltage and the rpm of an engine
i find a code for rpm and attached it to the code i had made for displaing the voltage
(here is the post for rpm code : http://forum.arduino.cc/index.php?topic=42837.0 )
As i am using for first time the attachInterrupt i am little confuse and not sure what is going wrong and cant get a reading for rpm (i am using a push button as a signal for testing it )
also i have one more Question about the attachInterrupt pin ( number 2 in pro mini)
Have to declare it in my code? also have to place any pull down resistor ?
the rpm will be from vechicles coil through optocoupler to isolate (safety) the signal from arduino input as the coil uses 12v
engine 4 stroke 4 cylinders up to 8.000 rpm maximum ( so i will have 4 signals per 1 revolution )
here is the code if anyone want to guide me.. thanks in Advance :
#include "U8glib.h"
U8GLIB_SSD1306_128X64 u8g(U8G_I2C_OPT_NO_ACK); // Display which does not send AC
bool first;
float analogA = 0.0; // Analog reading A1
////////////////////////////////////////////////////// RPM /////////////////////////////////////////////////////////////////////
// read RPM
int Cycle = 0; // set to 0 for PulseStartTime and set to
// 1 for PulseEndTime
unsigned long PulseStartTime; // Saves Start of pulse in ms
unsigned long PulseEndTime; // Saves End of pulse in ms
unsigned long PulseTime; // Stores dif between start and stop of pulse
unsigned long RPM = 0; // RPM to ouptut (30*1000/PulseTime)
void setup(void)
// flip screen, if required
//u8g.setRot180();
/////////////////////////////////////////////////////// Oled DISPLAY //////////////////////////////////////////////////////////
// assign default color value
if (u8g.getMode() == U8G_MODE_R3G3B2)
u8g.setColorIndex(255); // white
else if (u8g.getMode() == U8G_MODE_GRAY2BIT)
u8g.setColorIndex(3); // max intensity
else if (u8g.getMode() == U8G_MODE_BW)
u8g.setColorIndex(1); // pixel on
else if (u8g.getMode() == U8G_MODE_HICOLOR)
u8g.setHiColorByRGB(255, 255, 255);
attachInterrupt(0, RPMPulse, RISING); // Attaches interrupt to Digi Pin 2
//////////////////////////////////////////////////////////////////////////// RPM //////////////////////////////////////////////
void RPMPulse()
if (Cycle == 0) // Check to see if start pulse
PulseStartTime = millis(); // stores start time
Cycle = 1; // sets counter for start of pulse
return; // a return so it doesnt run the next if
if (Cycle == 1) // Check to see if end pulse
detachInterrupt(0); // Turns off inturrupt for calculations
PulseEndTime = millis(); // stores end time
Cycle = 0; // resets counter for pulse cycle
calcRPM(); // call to calculate pulse time
void calcRPM()
PulseTime = PulseEndTime - PulseStartTime; // Gets pulse duration
Serial.println("PulseTime ="); // Output pulse time for debug
Serial.println(PulseTime); // Pulse debug output
Serial.println(" ");
RPM = 30*1000/PulseTime*2; // Calculates RPM
attachInterrupt(0, RPMPulse, RISING); // re-attaches interrupt to Digi Pin 2
/////////////////////////////////////////////////////// END OF RPM CALCULATION //////////////////////////////////////////////////////////
void Meter(float* analogA)
u8g.setFont(u8g_font_fub11);
u8g.setFontRefHeightExtendedText();
u8g.setDefaultForegroundColor();
u8g.setFontPosTop();
//////////////////////////////////////////////////// printed words in display /////////////////////////////////////////////
//////////////////////////////////////////////////////// Sensor A /////////////////////////////////////////////////////////////////
u8g.drawStr(4, 20, "Volt");
int sensorValueA = analogRead(A1);
float x = sensorValueA * 5.0 / 1023.0 ;
u8g.setPrintPos(80, 20);
u8g.print(x);
////////////////////////////////////////////////////////Rpm Display /////////////////////////////////////////////////////////////////
u8g.drawStr(4, 40, "RPM");
u8g.setPrintPos(80, 40);
u8g.print(RPM);
/////////////////////////////////////////////////////// end of printed display /////////////////////////////////////////////////////
void loop(void){
if (first)
first = false;
u8g.firstPage();
do
Meter(&analogA);
while (u8g.nextPage());
////////////////////////////////// RPM SERIAL MONITOR////////////////////////////
Serial.println("RPM = "); // Output RPM for debug
Serial.println(int(RPM)); // RPM debug output
delay(2000);
