help with this code, pretty please !!!!
hi guys i was wondering if someone could help me with this code, it keeps saying “bounce does not name a type” then other errors with bits feel free to play around and see what anyone can do to help or get it working.
  • First Section: configure the periodical execution of a user
  • defined function (Interrupt service routine) using Timer2. This
  • example will run the function every 1ms.
#include <Bounce.h>
/* Timer2 reload value, globally available */
unsigned int tcnt2;
int pin1 = 12;
int pin2 = 11;
int counter = 0;
int oldCounter = 0;
// Instantiate a Bounce object with a 5 millisecond debounce time
// Only pin1 needs to be debounced. It is assumed that pin2
// will be stable when reading pin1
Bounce bouncer1 = Bounce( pin1,5 );
/* Second Section:
Use 3 74HC595 shift registers to display 3 numbers on
common cathode 7-segments LEDs, and one more 595 to turn a series of
10 LEDs on and off.
This code should work for any digit assembly, but was specifically
used to recuperate the digits of an old Line 6 floor board.
U1 pin 12 is Latch
U1 pin 11 is Clock
U1 pin 14 is Serial data input.
int LatchPin = 6;
int ClockPin = 5;
int DataPin = 7;
char m[4];
byte data;
byte dataArray[10]; //character segment matrice
int k = 100; //divider for number display
int showLed = 0x00; //led array
int dp1 = 0x00; //connected to LED 1
int dp2 = 0x00; //connected to LED 2
int dp3 = 0x00; //connected to decimal point on digit 1
//definitions for pedals and their LEDs
int express=1;
int oldExpressValue = 0;
int wah=2;
int oldWahValue = 0;
int swresist=0;
int resistValue;
int showTemp = 0;
//third section: MIDI
// general midi notes
char note1 = 60; //Middle C
char note2 = 62; //D
char note3 = 64; //E
char note4 = 65; //F
char note5 = 67; //G
char note6 = 69; //A
char lastCmd[3] = {0x00,0x00,0x00};
//Fourth Section: General setup
int pin13 = 13;
//setup for the display
pinMode(LatchPin, OUTPUT);
pinMode(ClockPin, OUTPUT);
pinMode(DataPin, OUTPUT);
//setup for the rotary encoder
pinMode(pin1, INPUT);
pinMode(pin2, INPUT);
Serial.begin(31250);
//This section for the Timer Interrupt
/* First disable the timer overflow interrupt while we’re configuring */
TIMSK2 &= ~(1<<TOIE2);
/* Configure timer2 in normal mode (pure counting, no PWM etc.) */
TCCR2A &= ~((1<<WGM21) | (1<<WGM20));
TCCR2B &= ~(1<<WGM22);
/* Select clock source: internal I/O clock */
ASSR &= ~(1<<AS2);
/* Disable Compare Match A interrupt enable (only want overflow) */
TIMSK2 &= ~(1<<OCIE2A);
/* Now configure the prescaler to CPU clock divided by 128 */
TCCR2B |= (1<<CS22) | (1<<CS20); // Set bits
TCCR2B &= ~(1<<CS21); // Clear bit
/* We need to calculate a proper value to load the timer counter.
  • The following loads the value 131 into the Timer 2 counter register
  • The math behind this is:
  • (CPU frequency) / (prescaler value) = 125000 Hz = 8us.
  • (desired period) / 8us = 125.
  • MAX(uint8) + 1 - 125 = 131;
    Save value globally for later reload in ISR */
    tcnt2 = 131;
/* Finally load end enable the timer */
TCNT2 = tcnt2;
TIMSK2 |= (1<<TOIE2);
  • Install the Interrupt Service Routine (ISR) for Timer2 overflow.
  • This is normally done by writing the address of the ISR in the
  • interrupt vector table but conveniently done by using ISR() /
    ISR(TIMER2_OVF_vect) {
    Reload the timer */
    TCNT2 = tcnt2;
bouncer1.update();
if(bouncer1.risingEdge()){
oldCounter = counter;
if (digitalRead(pin2)){
counter–;
else{
counter++;
//End of Timer Interrupt section
//Define character images in an array
dataArray[0] = 0x3f; // 0
dataArray[1] = 0x06; // 1
dataArray[2] = 0x5B; // 2
dataArray[3] = 0x4F; // 3
dataArray[4] = 0x66; // 4
dataArray[5] = 0x6D; // 5
dataArray[6] = 0x7C; // 6
dataArray[7] = 0x07; // 7
dataArray[8] = 0x7F; // 8
dataArray[9] = 0x67; // 9
//Read pedal values and show reading from 0 - 127
//need to be calibrated by hand for now. Routine to come
int expressValue = map(analogRead(express),950,85,0,127);
if (expressValue < (oldExpressValue-1) || expressValue > (oldExpressValue+1)) {
showValue(expressValue);
oldExpressValue = expressValue;
midiCmd(0xB0,0x0B, char(expressValue));
int wahValue = map(analogRead(wah),950,85,0,127);
if (wahValue < (oldWahValue-1) || wahValue > (oldWahValue+1)) {
showValue(wahValue);
oldWahValue = wahValue;
midiCmd(0xB0,0x07,char(wahValue));
//treat resistor value. No switch pressed = 916/1024
//leds 10,8,7 as MSB then6,5,4 and 3 as LSB binaries
//into variable showLed
resistValue = analogRead(swresist);
if ((resistValue > 750) && (lastCmd[1] == char(0x90)) && (lastCmd[2] != 0x00)){ //no pedal pressed → all notes off
midiCmd(0x90,lastCmd[2],0x00);
lastCmd[2] = 0x00;
// Serial.println(resistValue);
if (resistValue < 10){
//Tuner ON
showLed = 0x80;
if(digitalRead(pin13) == LOW)
digitalWrite(pin13,HIGH);
digitalWrite(pin13,LOW);
if (resistValue >= 35 & resistValue < 50){
//Effect control OR Channel Select
//Using LED 1 & 2
delay(500); //wait for switch release. Might need interrupt
if (dp1 == 0x00){
dp1 = 0x80;
dp2 = 0x00;
dp3 = 0x00;
}else {
dp1 = 0x00;
dp2 = 0x80;
dp3 = 0x00;
showLed = 0x00;
if (resistValue >= 142 & resistValue < 155){
if(lastCmd[2] != note1)
midiCmd(0x90, note1, 0x45);
showLed = 0x01;
if (resistValue >= 205 & resistValue < 215){
if(lastCmd[2] != note2) midiCmd(0x90, note2, 0x45);
showLed = 0x02;
if (resistValue >= 270 & resistValue < 290){
if(lastCmd[2] != note3) midiCmd(0x90, note3, 0x45);
showLed = 0x04;
if (resistValue >= 350 & resistValue < 500){
if(lastCmd[2] != note4) midiCmd(0x90, note4, 0x45);
showLed = 0x08;
if (resistValue >= 575 & resistValue < 585){
//Enter special mode. Light left Decimal point
dp1 = 0x00;
dp2 = 0x00;
dp3 = 0x80;
if (resistValue >= 640 & resistValue < 650){
if(lastCmd[2] != note5) midiCmd(0x90, note5, 0x45);
showLed = 0x10;
if (resistValue >= 710 & resistValue < 720){
if(lastCmd[2] != note6) midiCmd(0x90, note6, 0x45);
showLed = 0x20;
//Getting ready to display values and indicators
if (counter < 0 || counter > 999)
counter = 0;
if (oldCounter != counter){
showValue(counter);
midiCmdShort(0xC0,counter);
//Show me the number!
liteUpDisplay();
delay(5);
} /////END of LOOP
//Prepare array to cascade down shift registers
void showValue(int showNumber) {
int k = 100;
for (int i = 2; i >= 0; i–)
m = showNumber / k;
showNumber = showNumber - (m * k);
k = k / 10;
//Display 3 digits and one of 3 indicators
void liteUpDisplay(){
digitalWrite(LatchPin, LOW);
//rightmost digit. Use | (or) with 0x80 to light led 2
shiftOut(DataPin, ClockPin, MSBFIRST, dataArray[m[0]] | dp1);
//middle digit. Use | (or) to light led 1
shiftOut(DataPin, ClockPin, MSBFIRST, dataArray[m[1]] | dp2);
//lefmost digit. Use | (or) to light decimal point
shiftOut(DataPin, ClockPin, MSBFIRST, dataArray[m[2]] | dp3);
//leds 10,8,7 then6,5,4 and 3 as MSB and LSB binaries
shiftOut(DataPin, ClockPin, MSBFIRST, showLed);
digitalWrite(LatchPin, HIGH);
// Send a MIDI Command with 3 parts
void midiCmd(char cmd, char data1, char data2) {
lastCmd[1] = cmd;
lastCmd[2] = data1;
lastCmd[3] = data2;
Serial.print(cmd, BYTE);
Serial.print(data1, BYTE);
Serial.print(data2, BYTE);
// Send a MIDI Command with 2 parts
void midiCmdShort(char cmd, char data1) {
lastCmd[1] = cmd;
lastCmd[2] = data1;
It looks as if your library isn't being imported. Is it in the right place? The error message you're getting is what happens when C++ doesn't know about a class:
http://cplusplus.syntaxerrors.info/index.php?title=%E2%80%98Foo%E2%80%99_does_not_name_a_type
ah i see, ok i have managed to get it to compile however the other message i had come up was with the “Byte” sections near the bottom of my original message, here is what i have changed it to and now compiles but is it going to achieve the same? btw i just took the word “Byte” out and left the brackets.
here is the new code notice the change at the bottom, thank you for your support btw;
#include <Bounce.h>
unsigned int tcnt2;
int pin1 = 12;
int pin2 = 11;
int counter = 0;
int oldCounter = 0;
/* Second Section:
10 LEDs on and off.
U1 pin 12 is Latch
U1 pin 11 is Clock
int LatchPin = 6;
int ClockPin = 5;
int DataPin = 7;
char m[4];
byte data;
int express=1;
int wah=2;
int swresist=0;
int resistValue;
int showTemp = 0;
int pin13 = 13;
ASSR &= ~(1<<AS2);
    tcnt2 = 131;
TCNT2 = tcnt2;
    Reload the timer */
    TCNT2 = tcnt2;
bouncer1.update();
counter–;
else{
counter++;
lastCmd[2] = 0x00;
//Tuner ON
showLed = 0x80;
//Using LED 1 & 2
if (dp1 == 0x00){
dp1 = 0x80;
dp2 = 0x00;
dp3 = 0x00;
}else {
dp1 = 0x00;
dp2 = 0x80;
dp3 = 0x00;
showLed = 0x00;
showLed = 0x01;
showLed = 0x02;
showLed = 0x04;
showLed = 0x08;
dp1 = 0x00;
dp2 = 0x00;
dp3 = 0x80;
showLed = 0x10;
showLed = 0x20;
counter = 0;
showValue(counter);
liteUpDisplay();
delay(5);
} /////END of LOOP
int k = 100;
m = showNumber / k;
* k = k / 10;*
* digitalWrite(LatchPin, LOW);*
* //rightmost digit. Use | (or) with 0x80 to light led 2*
* shiftOut(DataPin, ClockPin, MSBFIRST, dataArray[m[0]] | dp1);*
* //middle digit. Use | (or) to light led 1*
* shiftOut(DataPin, ClockPin, MSBFIRST, dataArray[m[1]] | dp2);*
* //lefmost digit. Use | (or) to light decimal point*
* shiftOut(DataPin, ClockPin, MSBFIRST, dataArray[m[2]] | dp3);*
* //leds 10,8,7 then6,5,4 and 3 as MSB and LSB binaries*
* shiftOut(DataPin, ClockPin, MSBFIRST, showLed);*
* digitalWrite(LatchPin, HIGH);*
* lastCmd[1] = cmd;*
* lastCmd[2] = data1;*
* lastCmd[3] = data2;*
* Serial.print(cmd);*
* Serial.print(data1);*
* Serial.print(data2);*
Read this before posting a programming question
In particular:
Please edit your posts, select the code, and put it between [code][/code] tags.
And make the thread title meaningful. Everyone needs help. How about: "Having problems compiling sketch using Bounce library"?
