Hey everyone, I need some help if you could with my project. What I have here is an arcade machine that I have built that runs off a raspberry pi. To power that on and off I have my Uno, that runs off an HC-SR04 disctance sensor.
The idea is that when the UNO detects a player has approached the console say <50cm, the UNO pauses for a few seconds to confirm the person is actually standing there and not just passing by, then truns the PI on and boots the arcade up.
When the player walks away, the UNO reads that the player is not there anymore say >50cm and then pauses for 15 seconds in case the player has gone to grab their drink etc, then powers the system down.
In each case during that pause time the uno should be taking readings from the sensor and ensuring that that threshold of 50cm is consistently either higher or lower in that time so as not to power off or on unexpectedly.
what i am finding is that the UNO is constantly reading the distance, and rapiddly flicking the relay on or off ignoring the timers, i also finding that the sensor may read say:
5,5,5,6,6,4,5,5,2357,5,4,5,5...etc
Since its not paying attention to the timer it flicks the relay off thus turning everything off for that brief millisecond where it threw a bizzare distance read.
how can i slow the distance reads, to eliminate those faulty distance reads, and can you see where the timers are not working correctly?
I am sure this code can be cleaner, I am not very well versed in code. What I have here is lots of snippets that I have been pinching from one tutorial or another. I have been working on this for months with variations to this here and there and no luck getting the result i am after. I suspect that the solution will be a fairly simple syntax or formatting issue, but i don't really know.
note: in the code i have attached i have stripped out the leds fade up when powerd on and fade down when powering off, to make this easier for you guys to look through. so you might spot the references to those in there that are not actioned
what do you think??
// Arcade By Dave Lobato
// davidlobato.dl@gmail.com
// last updated: 25/07/2021 by: Dave Lobato
#include "Arduino.h"
#include <FastLED.h>
#include <Pushbutton.h>
#define BUTTON_PIN 4
#define RELAY_PIN 13
#define MARQUEE_PIN 7
#define BACKLIGHT_PIN 6
#define COLOR_ORDER GRB
#define CHIPSET WS2812B
#define NUM_LEDS_MARQ 104 //Change to match number of LEDs in Marquee.
#define NUM_LEDS_BACK 150 //Change to match number of LEDs on backlighting
Pushbutton pbutton1(BUTTON_PIN);
CRGB Mleds[NUM_LEDS_MARQ];
CRGB Bleds[NUM_LEDS_BACK];
int count = 0;// used for the switch case top cycle led patterns
const int trigPin = 9;// set up for ultrasonic proxy sensor
const int echoPin = 10;
long duration;
int Distance;
bool Player = false;
const unsigned long pStart = 2000;//---interval from player detections to power up system---
const unsigned long pLeave = 15000;//---interval from player leaving to power off---
unsigned long PlayerMillis = 0; // set up for player detection imers
unsigned long PrevPlayerMillis = 0;
unsigned long NoPlayerMillis = 0; // set up for no player detected timers
unsigned long PrevNoPlayerMillis = 0;
const long interval = 50;
int Brightness = 10; // ------ sets amount to fade the leds by-----
pinMode(trigPin, OUTPUT); //---------sets up the proxy sensor-----
pinMode(echoPin, INPUT);
pinMode(RELAY_PIN, OUTPUT); //---------sets up the mains relay for the rasberry pi--------
digitalWrite(RELAY_PIN, LOW);
pinMode(MARQUEE_PIN, OUTPUT); //---------sets up the marquee lights and the backlighting-------
pinMode(BACKLIGHT_PIN, OUTPUT);
FastLED.addLeds<CHIPSET, BACKLIGHT_PIN, COLOR_ORDER>(Bleds, NUM_LEDS_BACK).setCorrection( TypicalLEDStrip );
FastLED.addLeds<CHIPSET, MARQUEE_PIN, COLOR_ORDER>(Mleds, NUM_LEDS_MARQ).setCorrection( TypicalLEDStrip );
FastLED.setBrightness( 150 ); // --------Sets master brightness to begin illuminating-------------
for (int j = 0; j < NUM_LEDS_MARQ; j++) { //---------turn off all LEDS to begin...
Mleds[j] = CRGB::Black;
for (int j = 0; j < NUM_LEDS_BACK; j++) {
Bleds[j] = CRGB::Black;
FastLED.show();
LedCycle(); // activates switch case cycle function for the led patterns
digitalWrite(trigPin, LOW); // ultrasonic proximity sensor process
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
Distance = (duration * .0343) / 2; // sets distance to cm's
Serial.println(Distance); // prints distance to monitor
if (Distance <= 50) { // player is close to console--
PlayerMillis = millis(); // starts player present timer--
Player = true; // declares player present--
Serial.println("Player Found");
if (PlayerMillis - PrevPlayerMillis > pStart) { // check the time a player has been present for
digitalWrite(RELAY_PIN, HIGH); // power on the system
Serial.println("System Activated");
PrevPlayerMillis += PlayerMillis; // save the time the player was last detected
if (Distance > 50) { // no player detected near to console
NoPlayerMillis = millis(); // starts no player present timer
Player = false; // declares player not present
Serial.println("No Player Found");
if (NoPlayerMillis - PrevNoPlayerMillis > pLeave) { // check how long the player has been missing
digitalWrite(RELAY_PIN, LOW); // if long enough power, off the system
Serial.println("System DeActivated");
PrevNoPlayerMillis += NoPlayerMillis; // save the last time no player was detected
} // -----------------------------------------END LOOP-----------------------------------------------------//
void LedCycle() {// switch case funcion uses a momentary button to cycle through led patterns, this works well
if (pbutton1.isPressed()) { //-----press button to cycle LED patterns-----
count = count + 1;
delay(400);
switch (count) {
case 0:
movingDots();
case 1:
rainbowBeat();
case 2:
redWhiteBlue();
case 3:
DarkBlue();
case 4:
DarkRed();
case 5:
Indigo();
case 6:
count = 0;
FastLED.show();
//-------- the following are all the led patterns for the back lighting
void movingDots() {
uint16_t posBeat = beatsin16(30, 0, NUM_LEDS_BACK - 1, 0, 0);
uint16_t posBeat2 = beatsin16(60, 0, NUM_LEDS_BACK - 1, 0, 0);
uint16_t posBeat3 = beatsin16(30, 0, NUM_LEDS_BACK - 1, 0, 32767);
uint16_t posBeat4 = beatsin16(60, 0, NUM_LEDS_BACK - 1, 0, 32767);
// Wave for LED color
uint8_t colBeat = beatsin8(45, 0, 255, 0, 0);
Bleds[(posBeat + posBeat2) / 2] = CHSV(colBeat, 255, 255);
Bleds[(posBeat3 + posBeat4) / 2] = CHSV(colBeat, 255, 255);
fadeToBlackBy(Bleds, NUM_LEDS_BACK, 10);
void rainbowBeat() {
uint16_t beatA = beatsin16(30, 0, 255);
uint16_t beatB = beatsin16(20, 0, 255);
fill_rainbow(Bleds, NUM_LEDS_BACK, (beatA + beatB) / 2, 8);
void redWhiteBlue() {
uint16_t sinBeat = beatsin16(30, 0, NUM_LEDS_BACK - 1, 0, 0);
uint16_t sinBeat2 = beatsin16(30, 0, NUM_LEDS_BACK - 1, 0, 21845);
uint16_t sinBeat3 = beatsin16(30, 0, NUM_LEDS_BACK - 1, 0, 43690);
Bleds[sinBeat] = CRGB::Blue;
Bleds[sinBeat2] = CRGB::Red;
Bleds[sinBeat3] = CRGB::White;
void DarkBlue() {
Bleds[j] = CRGB::DarkBlue;
FastLED.show();
void DarkRed() {
Bleds[j] = CRGB::DarkRed;
FastLED.show();
void Indigo() {
Bleds[j] = CRGB::Indigo;
FastLED.show();
