So I am an arduino newb trying to get this program setup. Basically it controls a relay which creates rain in my chameleon enclosure. Here is the code I have that seems to work:
int relayPin = 7;
int button1 = 4;
int button2 = 3;
int rainduration = 30000;
unsigned long interval = 7200000; // the time between rain
unsigned long previousMillis = 0; // millis() returns an unsigned long.
void rain(){//defines rain
digitalWrite(relayPin, HIGH);
delay (rainduration);
digitalWrite(relayPin, LOW);//rain will turn on the relay for rainduration/60 sec
pinMode(relayPin, OUTPUT);
pinMode(button1, INPUT);
pinMode(button2, INPUT);
rain();//rain once on startup
if ((millis() - previousMillis) >= interval) {
previousMillis = millis();
rain(); //if 3 hours have elapsed, run rain and update previous millis
if(digitalRead(button2)== HIGH) //reads button 2
digitalWrite(relayPin, HIGH); //turns rain on for 30 sec
delay(30000);
delay (10);
So relaypin is the pin that controls the relay/water pump. I have the arduino hooked into the timer that controls the lights in the terrarium, so the arduino turns off at night and on every morning. rainduration is how long I want it to rain for and interval is how often it rains. I currently have it set for 30 seconds of rain every two hours. Now for some reason when I set rainduration for 45000 it goes past 45 sec and won't stop raining. I also tested a shorter interval of 5601000 and had no luck when 300000 worked fine. I also had some button functions I was working on but commented them out in order to trouble shoot. Any advise or ideas as to why I'm having issues? Thanks.
