Help with timing
I need help with timing between digitalWrites with out using delays. I have searched and read but cant quite figure it out. I put comments in the code where I need Help.
Please can someone can point me in the right direction. Thanks!
const int buttonPin = 2;
const int ledPin =  13;
const int ledPin1 = 4;
int buttonState = 0;
  pinMode(ledPin, OUTPUT);
  pinMode(buttonPin, INPUT);
  pinMode(ledPin1, OUTPUT);
  buttonState = digitalRead(buttonPin);
  if (buttonState == HIGH) {
    digitalWrite(ledPin1, HIGH);
   // wait .5 seconds then
    digitalWrite(ledPin, HIGH);
  else {
    digitalWrite(ledPin, LOW);
    //wait 4 seconds then
    digitalWrite(ledPin1, LOW);
before you can decide how to write a millis timer you need to decide what its meant to do based on the button.
if the person keeps the button pressed what does it do
if the person releases the button what does it do
if the person presses the button while its running what does it do
Look at the 'blink without delay' example in the Learning pages of this site or in the IDE.
Once you understand how that works, you will understand how to use it in your own programs.
classof1980:
To delay without using delays, you need to basically do this (imagine a 10 second delay):
(A) Get the current time in milliseconds (call it "snapshot")
(B) Is the current time less than "snapshot + 10000"?
(C) If YES, go back to B, if NO, 10 seconds have elapsed.
Now let's do it in real code. We will make an LED blink on and off (1/2 second on and 1/2 second off). 1/2 second is 500 milliseconds.
volatile uint32_t st; // st is "start time"
void setup (void)
    pinMode (13, OUTPUT); // use the board LED as an indicator
    while (1) { // do it forever
        digitalWrite (13, HIGH); // turn on the LED
        st = millis (); // snapshot the current time
        while (millis () > (st + 500)); // loop here until actual time > start + 500
        digitalWrite (13, LOW); // LED off
        st = millis (); // new snapshot
        while (millis () > (st + 500)); // same as before, wait for start + 500
void loop (void)
    // do nothing
See what this does? Now granted you are not "gaining" anything by simply hanging in a loop waiting for "ts+500" over plain old delay(), but a more complicated program could be DOING SOMETHING ELSE inside that waiting loop whereas if you use delay() you can't do anything else. Get it?
The demo Several Things at a Time is an extended example of BWoD and includes code for a button switch.
...R
