Help with timings
So, I’m building an 8-step sequencer using the Arduino IDE, and I got to the part where I configure period duration using a pot. And it does work, but it doesn’t work the way I expect. I’ve been looking at my code for hours, and I just can’t figure out what went wrong, so I was hoping that someone here could give me a hand :frowning:
Here’s the relevant code, from the “loop” section:
  // Playing speed regulation, using a pot:
  int speedPot = analogRead(POT1); // This pot determines T duration
  float T_step = 0.89; // [ms], T_step=(1000ms-100ms)/1024
  float T = 100 + speedPot * T_step; // [ms], T= t_ON + t_OFF, length of one period
  if (millis() - T_timer < T) { // This is the step scope
   digitalWrite(LED[stepCounter], HIGH);
  } else { // time T passed, time to move on
    T_timer = millis();
    digitalWrite(LED[stepCounter], LOW);
    if (stepCounter == 7)
      stepCounter = 0;
      stepCounter++;
So, the first part is determining the T duration. I wanted it to go from 0.1-1 s, or, 100+[0-1023]*0.89 [ms], roughly.
My sequencer has 8 LEDs, and in the second part I wanted to test the setup by turning each LED for a period T, and then jumping to the next period/LED, where T is determined by the pot position. And it does that, but instead of 0.1-1s, I get around 2-20s. What did I do wrong?
I declared timers as type “long”, but for T I used the type “float”. Is that a problem, can those two be in an equation?
I will attach the whole code if needed, but it’s still under construction, so it’s very messy.
They should really be unsigned long to match the value returned by millis() and to avoid possible problems with negative values.
I suspect the line
T_timer = millis();
should be part of the IF and not part of the ELSE.
Just realized your code is the opposite to the way I do it.
Also note that
T_timer += T;
is more accurate as it avoids any accumulation of errors. This is discussed at great length in Several Things at a Time
…R
hi
i’m trying to do the same but on a big scale with SD card ( i also have a example with Arrays on Sram)
i can controll 512 outputs with Fade and scene time + tapsync.
not yet made a function to controll scenetime with relevant fade time with pot controll
i did made a pot master dimmer.
and its made for the DUE so you need to decrease the arrays size to fit it on a uno or mega.
take a look at my example maby it will help you.
SequencerSD.zip (2.84 KB)
What board are you using? It's not by any chance a ATmega on a breadboard that hasn't been bootloaded, is it? (they come set to run at 1mhz off internal osc, so if you're compiling sketch for 16mhz board, things will run at 1/16th of the speed you expect)
@UKHelyBob, Robin 2: Thank you, I will try those things now, and see what happens.
@spirit: My setup is much more modest, but I will take a look at yours.
@DrAzzy: My chinese seller claimed that these chips were bootloaded for Arduino Uno, so I assume they are running on 16MHz. THIS is my setup, I'm not using the Arduino board, but the USBAsp programmer, so I assume that bootloader is gone now. I never tried the chip on the Arduino board.
DrAzzy: What board are you using? It's not by any chance a ATmega on a breadboard that hasn't been bootloaded, is it? (they come set to run at 1mhz off internal osc, so if you're compiling sketch for 16mhz board, things will run at 1/16th of the speed you expect)
Hey, I just set the T to be 1000ms, recorded the video, and measured 16s, just like you said. The whole time, I was using Arduino IDE with "Arduino/Genuino UNO" and "USBAsp" settings, and it didn't report any errors. How do I switch to 16MHz using USBAsp?
EDIT:
There's a "Burn Bootloader" option in Arduino IDE, would that change the clock on a 1MHz chip to 16MHz, or I have to do the Avrdudy fusy thingy? :)
ANOTHER EDIT:
I was impatient so I just went for it, AND IT WORKS! ^^ Thanks guys!
