Hi everyone,
I’m using an Arduino Nano ESP32 (based on the ESP32-S3 chip) with MicroPython (MicroPython v1.24.0), and I need help establishing a secure connection to a network that requires TLS with certificate authentication.
- The network I’m trying to connect to requires a CA certificate (typically provided as
.pem
or.crt
file). - I’ve uploaded the CA certificate to the filesystem on the ESP32.
- However, the MicroPython build currently installed on the board seems to lack the
ussl
module, which is required for TLS connections. Runningimport ussl
results in a "No module named 'ussl'" error.
- Does the MicroPython firmware provided by Arduino officially support TLS? If so, how can I enable or add the
ussl
module? - Is it safe to flash a generic MicroPython build (e.g., for ESP32-S3) to the Arduino Nano ESP32, or are there specific configurations required for this board?
- Are there any other solutions (e.g., using Arduino IDE or CircuitPython) that would allow me to achieve a secure connection with TLS and certificate authentication?
I’d appreciate any guidance or example projects/code snippets that can help me achieve this!
Thanks in advance for your support!
