I am making a complex project that needs to use transistors to "trigger" certain events that is greater than an adruino's voltage.
An example of this is I need to use 30V or higher to use on the project than 5 or 9V than the arduino uses.
The main problem is can one pin connect at least 2 or more GATES in a transistor? (the middle prong in the transistors) AND does it have to hit ground on the pins once complete, or is there a different way?
If not is there a way to insert multiple programming by switch? The switch is an input I think.
can you show the diagram exactly? its hard for me to read words sometimes without pictures. So after one gate add a resistor then so on? all connected in series? or parallel?
NitroXAce:
It would be quicker for you to Google it, than come back to me if you are unclear.
Bainesbunch:
you can drive multiple MOSFET gates from a single Arduino output, be sure to use a resistor for EACH gate however.
NitroXAce:
NPN's would be trickier because to fully saturate you need around 200ohms but that also taxes you on current, so try not to go over 30ma total draw....
NitroXAce:
I kind of meant NPN and PNP, but I will take the FET's on consideration, but what setup does it need extra to work?
It's relative to the collector current required.
cjdelphi:
That's relative to the collector current required, too.
So, there's not a one-size-fits-all solution that I can just plop before you.
I could say, "well, just overdrive the crap out said transistor", but that'd be kind of clumsy like.
MOSFETs don't have the input current : output current relationship that bipolar transistors do.
You'll have to be more forthcoming about what you're trying to switch on the 30V.
NitroXAce:
I'm not poking fun or trying to be a hard-adze, but What are we talking about here?
