help with two pir's code?
hi i have two pir sensors and two rooms,i want to put one pir in each room,and have it with on a light in that room when mothin is detected,i got one room to work,but im having a little trouble with adding the code for the other one is that possible on the arduino?
this is what works rite now…
int room1 = 2;
int room2 = 3;
int motionroom1 = 7;
int motionroom2 = 8;
pinMode(motionroom1,INPUT);
pinMode(room1,OUTPUT);
pinMode(room2,OUTPUT);
//--------------vTEST--------------------------------//
digitalWrite(room2,HIGH);
digitalWrite(room1,LOW);
digitalWrite(room1,HIGH);
digitalWrite(room2,LOW);
delay(4000);
delay(4000);
//--------------------end test------------------------------------
if (digitalRead(motionroom1) == HIGH)
delay(250000);
Why isn't motionroom2 declared to be an INPUT pin?
    delay(250000);
Don't you think that it is necessary to read the other sensor? Motion in the other room won't be detected for more than 6 minutes if there is motion on the first room.
My crystal ball tells me that study of the blink without delay example is in your future.
i do think so i just forgot to put it there in this example but i have it in my sketch
