here is code
const int buttonPin = 0;
// neopixel pin will be PIN
#define PIN 6
volatile int buttonPushCounter =10;
volatile int buttonState = 0;
volatile int lastButtonState = 0;
volatile int oldButton = 0;
volatile int mode;
//declare strip
// Parameter 1 = number of pixels in strip
// Parameter 2 = Arduino pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
// NEO_KHZ800 800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
// NEO_KHZ400 400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
// NEO_GRB Pixels are wired for GRB bitstream (most NeoPixel products)
// NEO_RGB Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
// NEO_RGBW Pixels are wired for RGBW bitstream (NeoPixel RGBW products)
Adafruit_NeoPixel strip = Adafruit_NeoPixel(12, PIN, NEO_GRB + NEO_KHZ800);
pinMode (buttonPin , INPUT);
strip.begin();
strip.show(); // Initialize all pixels to 'off'
pinMode (2 , INPUT);
attachInterrupt(digitalPinToInterrupt(2), buttonCountUp , CHANGE );
void loop (){
/* buttonState = digitalRead(buttonPin);
if (buttonState != lastButtonState){
if(buttonState == HIGH){
buttonPushCounter++;
if ( buttonPushCounter > 10) { buttonPushCounter = 0 ;
Serial.println("on");
Serial.print("number of button pushes:");
Serial.println(buttonPushCounter);
}else{
Serial.println("off");
mode = ( buttonPushCounter );
Serial.print("mode:");
Serial.println(mode);
while(mode == 0) {
while(mode == 1) {
Serial.println("Theatre chase rainbow:");
theaterChaseRainbow(50);
while(mode == 2) {
Serial.println("Red:");
theaterChase(strip.Color(255, 0, 0), 50); // Red
while(mode == 3) {
Serial.println("Green:");
theaterChase(strip.Color(0, 255, 0), 50); // Green
while(mode == 4) {
Serial.println("Blue:");
theaterChase(strip.Color(0, 0, 255), 50); // Blue
while(mode == 5) {
Serial.println("Rainbow:");
rainbow(20);
while(mode == 6) {
Serial.println("Rainbow Cycle:");
rainbowCycle(20);
while(mode == 7) {
Serial.println("Thatere chase:");
theaterChase(strip.Color(127, 127, 127), 50); // White
while(mode == 8) {
colorWipe(strip.Color(random (0,255), random (0,255), random(0,255)), 250);
while(mode == 9) {
colorWipe(strip.Color(random (0,255), random (0,255), random(0,255)), 50);
while(mode == 10) {
colorWipe(strip.Color(random (0,255), random (0,255), random(0,255)), 25);
if ( buttonPushCounter = 0 ){
else if ( buttonPushCounter = 1) {
else if ( buttonPushCounter = 2) {
// end check button code
//lastButtonState = buttonState;
//interrupt code
void buttonCountUp () {
Serial.println ("Interrupt!");
Serial.print ("button Push Counter:");
Serial.println ( buttonPushCounter );
Serial.print ("button state:");
Serial.println (buttonState);
Serial.print ("New Last button state:");
Serial.println ("button is pushed!");
Serial.println ("counter increased!");
Serial.println("end of button push");
// sends to restart
} //end interupt code
//start neo pixel code
void colorWipe(uint32_t c, uint8_t wait) {
for(uint16_t i=0; i<strip.numPixels(); i++) {
strip.setPixelColor(i, c);
strip.show();
delay(wait);
void rainbow(uint8_t wait) {
uint16_t i, j;
for(j=0; j<256; j++) {
for(i=0; i<strip.numPixels(); i++) {
strip.setPixelColor(i, Wheel((i+j) & 255));
strip.show();
delay(wait);
// Slightly different, this makes the rainbow equally distributed throughout
void rainbowCycle(uint8_t wait) {
uint16_t i, j;
for(j=0; j<256*5; j++) { // 5 cycles of all colors on wheel
for(i=0; i< strip.numPixels(); i++) {
strip.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()) + j) & 255));
strip.show();
delay(wait);
//Theatre-style crawling lights.
void theaterChase(uint32_t c, uint8_t wait) {
for (int j=0; j<10; j++) { //do 10 cycles of chasing
for (int q=0; q < 3; q++) {
for (uint16_t i=0; i < strip.numPixels(); i=i+3) {
strip.setPixelColor(i+q, c); //turn every third pixel on
strip.show();
delay(wait);
strip.setPixelColor(i+q, 0); //turn every third pixel off
//Theatre-style crawling lights with rainbow effect
void theaterChaseRainbow(uint8_t wait) {
for (int j=0; j < 256; j++) { // cycle all 256 colors in the wheel
strip.setPixelColor(i+q, Wheel( (i+j) % 255)); //turn every third pixel on
strip.show();
delay(wait);
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
WheelPos = 255 - WheelPos;
if(WheelPos < 85) {
return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
if(WheelPos < 170) {
WheelPos -= 85;
return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
WheelPos -= 170;
return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
