help with u8g2 libraries
i’ve edited some code from internet for clock with oled lcd (adafruit library), but i want to edit the code to use hx1230 lcd (u8g2 library) but my lcd show nothing.
if i try to write example code “hello world” to my hx1230, it was works fine
setcontrast not works even set from 0 to 255
teach me to solve my code, thanks
#include <Wire.h>
#include <Arduino.h>
#include <U8g2lib.h>
#include <SPI.h>
#define button1    5
#define button2    2
U8G2_HX1230_96X68_F_3W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 7, /* reset=*/ 6);
void setup(void)
  pinMode(button1, INPUT_PULLUP);
  pinMode(button2, INPUT_PULLUP);
  u8g2.setContrast(100);
  u8g2.begin();
char Time[]     = "  :  :  ";
char Calendar[] = "  /  /20  ";
byte i, second, minute, hour, day, date, month, year;
void u8g2_day()
    switch(day){
    case 1:  draw_text(0, 0, " Monday  ", 1); break;
    case 2:  draw_text(0, 0, " tuesday  ", 1); break;
    case 3:  draw_text(0, 0, " wednesday ", 1); break;
    case 4:  draw_text(0, 0, "thursday", 1); break;
    case 5:  draw_text(0, 0, "friday ", 1); break;
    case 6:  draw_text(0, 0, " saturday  ", 1); break;
    default: draw_text(0, 0, "sunday ", 1);
void DS1307_u8g2()
  second = (second >> 4) * 10 + (second & 0x0F);
  minute = (minute >> 4) * 10 + (minute & 0x0F);
  hour   = (hour >> 4)   * 10 + (hour & 0x0F);
  date   = (date >> 4)   * 10 + (date & 0x0F);
  month  = (month >> 4)  * 10 + (month & 0x0F);
  year   = (year >> 4)   * 10 + (year & 0x0F);
  Time[7]     = second % 10 + 48;
  Time[6]     = second / 10 + 48;
  Time[4]     = minute % 10 + 48;
  Time[3]     = minute / 10 + 48;
  Time[1]     = hour   % 10 + 48;
  Time[0]     = hour   / 10 + 48;
  Calendar[9] = year   % 10 + 48;
  Calendar[8] = year   / 10 + 48;
  Calendar[4] = month  % 10 + 48;
  Calendar[3] = month  / 10 + 48;
  Calendar[1] = date   % 10 + 48;
  Calendar[0] = date   / 10 + 48;
  draw_text(60,  0, Calendar, 1);
  draw_text(10, 19, Time, 2);
void blink_parameter()
  byte j = 0;
  while(j < 10 && digitalRead(button1)){
  j++;
  delay(25);
byte edit(byte x_pos, byte y_pos, byte parameter)
  char text[3];
  sprintf(text,"%02u", parameter);
  while(!digitalRead(button1));
  while(true){
    while(!digitalRead(button2)){
      parameter++;
      if(i == 0 && parameter > 31)
        parameter = 1;
      if(i == 1 && parameter > 12)
        parameter = 1;
      if(i == 2 && parameter > 99)
        parameter = 0;
      if(i == 3 && parameter > 23)
        parameter = 0;
      if(i == 4 && parameter > 59)
        parameter = 0;
      draw_text(x_pos, y_pos, text, 1);
      delay(200);
    draw_text(x_pos, y_pos, "  ", 1);
    blink_parameter();
    blink_parameter();
    if(!digitalRead(button1)){
    i++;
    return parameter;
void draw_text(byte x_pos, byte y_pos, char *text, byte text_size)
  u8g2.clearBuffer();
  u8g2.setFont(u8g2_font_siji_t_6x10);
  u8g2.setCursor(x_pos, y_pos);
  u8g2.println(text);
  u8g2.sendBuffer();
  delay(200);
    i = 0;
    while(true){
        day++;
        if(day > 7) day = 1;
        u8g2_day();
        delay(200);
      draw_text(0, 0, "         ", 1);
      blink_parameter();
      u8g2_day();
      blink_parameter();
    date   = edit(60, 0, date);
    month  = edit(80, 0, month);
    year   = edit(110,0, year);
    hour   = edit(14, 9, hour);
    minute = edit(50, 9, minute);
    minute = ((minute / 10) << 4) + (minute % 10);
    hour = ((hour / 10)  << 4) + (hour % 10);
    date = ((date / 10) <<  4) + (date % 10);
    month = ((month / 10)  << 4) + (month % 10);
    year = ((year / 10)  << 4) + (year % 10);
    Wire.beginTransmission(0x68);
    Wire.write(0);
    Wire.write(0);
    Wire.write(minute);
    Wire.write(hour);
    Wire.write(day);
    Wire.write(date);
    Wire.write(month);
    Wire.write(year);
    Wire.endTransmission();
    delay(200);
  Wire.write(0);
  Wire.endTransmission(false);
  Wire.requestFrom(0x68, 7);
  second = Wire.read();
  minute = Wire.read();
  hour   = Wire.read();
  day    = Wire.read();
  date   = Wire.read();
  month  = Wire.read();
  year   = Wire.read();
  Wire.write(0x11);
  Wire.requestFrom(0x68, 2);
  u8g2_day();
  DS1307_u8g2();
  delay(50);
and this is original code
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#define OLED_RESET 4
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
#define button1    5                       // Button B1 is connected to Arduino pin 9
#define button2    2                     // Button B2 is connected to Arduino pin 8
void setup(void) {
  // by default, we'll generate the high voltage from the 3.3v line internally! (neat!)
  display.begin(SSD1306_SWITCHCAPVCC, 0x3C);  // initialize with the I2C addr
  // init done
  // Clear the display buffer.
  display.clearDisplay();
  display.display();
  display.setTextColor(WHITE, BLACK);
 // display.drawRect(117, 25, 3, 3, WHITE);     // Put degree symbol ( ° )
char temperature_msb;
byte i, second, minute, hour, day, date, month, year, temperature_lsb;
void display_day(){
  switch(day){
void DS1307_display(){
  // Convert BCD to decimal
  // End conversion
  draw_text(60,  0, Calendar, 1);                     // Display the date (format: dd/mm/yyyy)
  draw_text(10, 19, Time, 2);                         // Display the time
 // draw_text(75, 25, temperature, 1);                  // Display the temperature
void blink_parameter(){
  byte j = 0;
    j++;
    delay(25);
byte edit(byte x_pos, byte y_pos, byte parameter){
  char text[3];
  while(!digitalRead(button1));                      // Wait until button B1 released
  while(true){
    while(!digitalRead(button2)){                    // If button B2 is pressed
      parameter++;
      if(i == 0 && parameter > 31)                   // If date > 31 ==> date = 1
        parameter = 1;
      if(i == 1 && parameter > 12)                   // If month > 12 ==> month = 1
        parameter = 1;
      if(i == 2 && parameter > 99)                   // If year > 99 ==> year = 0
        parameter = 0;
      if(i == 3 && parameter > 23)                   // If hours > 23 ==> hours = 0
        parameter = 0;
      if(i == 4 && parameter > 59)                   // If minutes > 59 ==> minutes = 0
        parameter = 0;
      delay(200);                                    // Wait 200ms
    blink_parameter();
    blink_parameter();
    if(!digitalRead(button1)){                       // If button B1 is pressed
      i++;                                           // Increament 'i' for the next parameter
      return parameter;                              // Return parameter value and exit
void draw_text(byte x_pos, byte y_pos, char *text, byte text_size) {
  display.setCursor(x_pos, y_pos);
  display.setTextSize(text_size);
  display.print(text);
  display.display();
    i = 0;
    while(!digitalRead(button1));                    // Wait for button B1 release
    while(true){
      while(!digitalRead(button2)){                  // While button B2 pressed
        day++;                                       // Increment day
        display_day();                               // Call display_day function
        delay(200);                                  // Wait 200 ms
      blink_parameter();                             // Call blink_parameter function
      if(!digitalRead(button1))                      // If button B1 is pressed
    //set position of text when editing on button press
    date   = edit(60, 0, date);                      // Edit date
    month  = edit(80, 0, month);                    // Edit month
    year   = edit(110,0, year);                    // Edit year
    hour   = edit(14, 9, hour);                     // Edit hours
    minute = edit(50, 9, minute);                   // Edit minutes
    // Convert decimal to BCD
    // End conversion
    // Write data to DS1307 RTC
    Wire.beginTransmission(0x68);               // Start I2C protocol with DS1307 address
    Wire.write(0);                              // Send register address
    Wire.write(0);                              // Reset sesonds and start oscillator
    Wire.write(minute);                         // Write minute
    Wire.write(hour);                           // Write hour
    Wire.write(day);                            // Write day
    Wire.write(date);                           // Write date
    Wire.write(month);                          // Write month
    Wire.write(year);                           // Write year
    Wire.endTransmission();                     // Stop transmission and release the I2C bus
  Wire.endTransmission(false);                  // I2C restart
  Wire.requestFrom(0x68, 7);                    // Request 7 bytes from DS1307 and release I2C bus at end of reading
  second = Wire.read();                         // Read seconds from register 0
  minute = Wire.read();                         // Read minuts from register 1
  hour   = Wire.read();                         // Read hour from register 2
  day    = Wire.read();                         // Read day from register 3
  date   = Wire.read();                         // Read date from register 4
  month  = Wire.read();                         // Read month from register 5
  year   = Wire.read();                         // Read year from register 6
  Wire.write(0x11);                             // Send register address
  Wire.requestFrom(0x68, 2);                    // Request 2 bytes from DS1307 and release I2C bus at end of reading
  temperature_msb = Wire.read();                // Read temperature MSB
  temperature_lsb = Wire.read();                // Read temperature LSB
  display_day();
  DS1307_display();                             // Diaplay time & calendar
  delay(50);                                    // Wait 50ms
Do you test your OLED with something simpler like a string?
robertoxyz20:
yes sir, pretty looks when i use oled
Did you try any library example sketch for the hx1230?
aarg:
not yet, cause i love any font from u8g2 library
voidnoob:
Maybe you would not see your favourite font. But you might troubleshoot your problem and solve it. Right now the problem could be in so many places, you need to isolate it.
aarg:
i dont know another library for this lcd too
voidnoob:
if i try to write example code "hello world" to my hx1230, it was works fine
I am confused. Does it show "hello world", or nothing?
Also, are you telling me that this library doesn't have any example code for various displays?
Did you write this, or get it somewhere?:
Please tell me you didn't just change the name of the display in there and expect it to work...
I am confused. Does it show "hello world", or nothing?if i use the sample code u8g2 lib, hx 1230 showing "hello world"
Also, are you telling me that this library doesn't have any example code for various displays?that's not what I mean, I just don't know of a library other than u8g2 which is suitable for hx1230
Did you write this, or get it somewhere?:no, that's the default constructor of u8g2 for hx1230Please tell me you didn't just change the name of the display in there and expect it to work...do you mean i change the lcd constructor?
If I compare your code
  u8g2.clearBuffer();  // ???????????????
  u8g2.println(text);
  u8g2.sendBuffer();
  delay(200);
with the original code
  display.display();
then I would say, that the difference would lead to unexpected results.
Oliver
