I am at my wits end with arduino programming and am finally reaching out for help . To date I have studied and copied a pile of code & text definitions from the tutorials point web site ....... I am just not falling in line with this c programming language .
I did the plc course with my local college and as confusing as that was , I stuck with it and proved fantastic results . Then ....... I found out about a fantastic little microcontroller called arduino and I have been driving myself crazy trying to sink it’s programming language into my head . I’m stubborn & not giving up but I do need some help .
My project(s) : their are lots but allow me to start with my first . An aquaponic green house
In this green house there will be many variables including water temp , atmospheric temp , flooding timers for media beds , water levels for adding more water due to evaporation , timers to operate automatic fish feeders , when to open ceiling vents , when to start circulation pumps for heated floors in house & tank for winter operation and a pile more gadgets .
Back to my point , I could say good bye arduino ( micro plcs are cheap too and at least I understand the logic ) but at this point I have a considerable amount of time invested
It feels as if I am on the cusp of grasping this language and only need a point in the right direction
I am sure you did not qualify to run in the marathon the day after you were born yet that is what you are attempting to do here. Like walking learn the basics first and do a lot of the tutorials that are on line. Then start one at a time with each hardware device you will be using and learn how to use it. They put it together.
All quite doable with Arduino boards. But rather than starting with diving into the deep end with a bowling ball, start small.
Buy an Arduino starter kit or sensor kit. Use a breadboard to experiment with the sensors in the kit and using the example programs (called sketches- long story, but irrelevant) in the IDE.
This way you will learn the basics of C++ (not C, but similar enough) and the Arduino IDE. If you then run into coding issues, then come here for help.
