Hi there,
I am looking to create an automated planting system as a way to learn electronics, however as i mentioned i am trying to learn, and i have hit a road block. I was looking at a grow light and i am getting a little confused about how to power it.
The light I am looking at can be found on Aliexpress, and displays the following power requirements
Power - 10 W
Direct voltage - 9-11 V
Direct current - 900mA
Luminous flow - 200-300LM
How is this read? and can i just attach this to my Arduino Uno and go? Or do i need to look into something else to help power this? Ideally I would like a single power cable for this project, is this possible?
You need a separate DC power supply capable of supplying 9-12 volts to the load. It must also maintain that voltage when the load is drawing 900ma. Get one with some headroom. That is, do not get a power supply that only provides the bare minimum 900ma. Many recommend 20% more than the given load will take.
Mechdude:
Absolute max. current on an Arduino I/O pin is 40ma and 200ma total for the chip so, no, you cannot power your project with the Arduino. The Arduino can switch other high current devices, like relays or MOSFETs which in turn will operate the load. Power = voltage x current.
Mechdude:
Yes. A [url=http://
Mechdude:
buck converter[/url] can take a small part of the main DC supply and step it down to power the Arduino. Done this way the converter becomes part of the load on the power supply.
Thanks for reply!
As mentioned i am using this as an exercise to learn, is this quite a simple thing to do? Or am i going to burn my house down lol?
the Arduino is a microCONTROLer. it specializes in control. it uses 5VDC to do this.
your mission, should you decide to accept it, is to interface that which you need controlled to that which controls. you need to find a power switching device that converts 5 VDC inputs to switch contacts that can handle your load
search terms: SSR ( Solid State Relay ); relay, MOSFET ( for big loads )
