Good afternoon,
To start with Im a newbie, so please be pateint with me
Ive decided to make my own alarm system for my home, and decided to use Ardunno, and XBee communications between the PIRs and door sensors. But I have 2 questions before buying all the kit.
As Im just reading the sensor (PIR), can I just connect the XBee directly into the PIR to transmit what the sensor sends, ie low for no movement, and when movement is detected High? Or do I need to connect every PIR to a Arduino board and then an XBee to transmit the status of the sensor?
Do I just need to 1 XBee for each Sensor, and then one for the Ardunio and the Ardunio can read the state of all XBees on the PAN, or can I only do XBee to XBee? I have not seen any documentation for how to read what XBee is sending the data on the PAN.
Thank you in advance, and Im sorry for my newbiness
